February 20, 2025, 05:59:32 PM *
Author Topic: Exhaust Diameter  (Read 1052 times)
hackers2r
« on: January 06, 2010, 07:31:34 AM »
I am looking at having a custom exhaust made for my S2R 800 but have an important question.  All the systems for my bike are 2-1-2.  If I were going to do a 2-1 system, what would the optimal size for the pipe to be?  My natural assumption is that since both header pipes are 45mm, the collector pipe should be 90mm.  Am I correct? Close? Completely wrong?  Thanks.
« Reply #1 on: January 06, 2010, 07:49:42 AM »
if something is to have the same flow suppose it would have to have the same cross sectional area... right?
Pipe Diameter   # of Pipes   Cross Sectional Area
45mm                 2   3179.25mm2
60mm               1   2826.00mm2
62mm               1   3017.54mm2
63mm               1   3115.67mm2
63.63962mm   1   3179.25mm2
64mm                1   3215.36mm2
65mm               1   3316.63mm2
Not sure you'll find a 63.63962mm dia. pipe... but it would be the same cross section
this is just a pure mathematical approach, i'm sure in practice it is much different.
hackers2r
« Reply #2 on: January 06, 2010, 07:56:55 AM »
Well that solves that question, mathematically speaking of course.  If anyone else has any insight, it would be greatly appreciated.
hackers2r
« Reply #3 on: January 06, 2010, 10:03:26 AM »
In addition, there was a link to a crossover pipe calculator posted on here once.  Anyone have it or know the proper distance for this motor?  Thanks.
greenmonster
« Reply #4 on: January 07, 2010, 04:02:24 PM »
Spaggetti systems, like SilMoto f e, has same diameter in crossection as rest of the tubing.
« Last Edit: January 08, 2010, 03:24:28 PM by greenmonster » Logged
M900 -97
MTS 1100s  -07
hackers2r
« Reply #5 on: January 14, 2010, 08:46:18 AM »
An additional question, does anyone have the inside diameter of the exhaust port on the S2R 800?  Thank.
Howley
« Reply #6 on: January 15, 2010, 12:56:43 AM »
You do if you have an S2R 800 and a ruler.
