February 06, 2025, 06:15:53 AM
Please Help
S4R won't start (not cold out)
Topic: S4R won't start (not cold out) (Read 4190 times)
va122
January 06, 2010, 04:49:33 PM »
Hi,
My S4R will not start. The headlight is bright, the fast idle is on, tach sweeps but when I push the starter I'll hear the starter cycle once or twice (max) and the bike won't turn over. The starter stops cycling after only once or twice which is weird. I tried jumping it, with no luck, same issue. I push started the bike and it started no problem, runs great. It will re-start once warm.
What do you think?
If you're going to walk on thin ice you might as well dance.
Duckintime
Re: S4R won't start (not cold out)
January 06, 2010, 05:37:33 PM »
Could be a number of things, including clutch lever switch, starter push button, or solenoid. Do you have a volt meter? Disconnect the clutch switch.. follow the wiring from the lever, and youll see a plug. Jump the two terminals together and then try to start it. At least that cancels out a bad switch. Check your battery connections for tightness, also follow the cables from the battery to where they connect. Make sure they are tight
DucHead
No garage queens
January 07, 2010, 05:03:15 AM »
The fact that it turns over eliminates the clutch safety switch, and perhaps the battery as well.
Sounds like a bad connection from the battery to the starter (jumping did not work), or a bad ground. Check the ground wire that runs from the battery negative to the engine case. If this is loose/corroded the bike will not start. This happened to me.
"45"
January 07, 2010, 06:22:55 AM »
Don't rule out the battery yet. It takes a lot less amperage to light the headlamp than it does to operate the starter motor. The fact that a jump doesn't help does pretty much eliminate the battery though. It is still a good idea to fully charge and load test the battery just to rule that out though. More likely is a bad connection or ground, particularly the engine ground. The best way to find a bad connection is by voltage drop.
http://www.aa1car.com/library/voltage_drop_testing.htm
If you need to clean the connection at the starter, BE CAREFUL. The lug on the starter is very delicate.
va122
January 07, 2010, 10:58:14 AM »
Hey Guys,
Thanks for the prompt response! I've already checked all the wires to see if one was loose and everything looks good
Well, I put the bike on a battery charger overnight and tried to start it today and it did indeed start AND the starter motor cycled like 5 times before the bike turned over. Before it would cycle only once and die.
I guess we're back to the battery issue. Right?
DucHead
No garage queens
January 07, 2010, 11:06:32 AM »
Still seems odd that you couldn't jump it.
"45"
va122
January 07, 2010, 11:28:24 AM »
I know, right?
Well when I jumped it I used the frame as a ground could it be the powdercoating isn't conductive?
For $50 you can touch my
January 07, 2010, 01:48:40 PM »
Quote from: va122 on January 07, 2010, 11:28:24 AM
I know, right?
Yeah, I know, we're not supposed to, but just go pos to pos and neg to neg. It works better.
WetDuc
AKA iamhybris
January 07, 2010, 01:55:12 PM »
Quote from: MrIncredible on January 07, 2010, 01:48:40 PM
Yup, I do it, too. Works everytime.
va122
January 07, 2010, 05:39:51 PM »
Cool, now how do I know If I need a new battery?
January 07, 2010, 06:13:01 PM »
Fully charge the battery and get it over to a shop with equipment to load test it. A less accurate shade tree method would be to place a volt meter across the battery, disable ignition and crank engine. Voltage should stay over 9.6 volts. If the battery is over four years old you might consider replacing it anyway, particularly on a fuel injected bike.
va122
January 08, 2010, 03:44:42 PM »
mine's 5 years old, I'll replace it.
