February 11, 2025, 09:43:45 PM *
Author Topic: Brake Pad Retaining Pin - Cotter Pin / Clip size?  (Read 1856 times)
loves ze desmodromics.
« on: January 07, 2010, 11:04:06 AM »
I don't have safety wire pliers. I will eventually buy them. Like, perhaps this summer. In the meantime, I need to pull my brake pads for some light scuffing, and when I put them back, and replace the retaining pin, I'd like it all to stay put. Currently, they are retained with a bit o' safety wire. The little e-clips or cotter pins have been lost over the years apparently.
Since the old stuff is a bit funky, I was contemplating throwing a few dollars at some shiny new titanium retaining pins. ProBolt and RaceBolts both advertise such a pin for brembo brakes. What size cotter pin would I use? (It looks like this would be easiest, and I see McMaster-Carr carries stainless ones, which I would prefer for corrosion purposes)
If it matters, I'm rocking the single pin goldlines (40mm mounts) and I have dark brown hair.
« Reply #1 on: January 08, 2010, 05:14:10 AM »
Really, nobody knows the size of the pin, where I can get spares cheap, or at least the diameter of standard safety wire?
battlecry
On a silver black phantom bike...
« Reply #2 on: January 08, 2010, 05:35:21 AM »
ATO:
I'm not near where I can help, but here is some info on the safety wire:
http://www.aircraftspruce.com/catalog/appages/safetywire.php
Can't recall which I use, but it is probably the 032 one.
I drill my safetywire holes using 1/16" bit.   But do not know about the clip diameter.
Maybe Yoyodine has the clips?
R
« Reply #3 on: January 08, 2010, 05:37:10 AM »
Great Reminder! I will check.
printman
Check out my a.....
« Reply #4 on: January 11, 2010, 03:16:10 PM »
I called Brembo and had them ship me out some cheap, when I noticed a retaining clip missing.  Give it a shot for the correct part.
I'll update this later at a convenient time Thank you for tuning in.....
evoasis
I lost my Titanium Member
« Reply #5 on: January 12, 2010, 09:42:09 PM »
I use 32/1000's safety wire on mine, and you  can just go with a set of pliers and wire cutters (dykes) and it'll be much safer than the crappy clips..
I guess there are good and bad mods; you'll find the good ones here Wink
