February 05, 2025, 05:06:31 PM *
News: Please Help
Author Topic: "Headlight" Fairing for track use - replacing headlight?  (Read 6094 times)
loves ze desmodromics.
« on: January 07, 2010, 01:27:16 PM »
I thought I had seen a fairing before (didn't see it in the old DP catalog pdf I have) that replaces the headlight for track use. Its like a headlight fairing, but instead of going above the headlight, it replaces the headlight too.
Can anybody help a brother out?
Any ideas you have regarding this. If you search "Ducati Monster Race Fairing" you get the new style headlight fairing that is tall with slits cut in it. Not what I'm looking for at all.
Here's an example of what I'm looking for, on an Aprilia Tuono:
http://kaemna.de/cms_en/katalog.htm?&view=artikel&artikel=1554
The idea I'm looking for is a front fairing to replace the headlight for track use that requires little-to-no modification of the bike. Just remove some parts, put it on, go play, go home and put it back together. Kind of a simple swap in and out. Or at least not as substantial a modification as figuring out how to mount a Supersport or Superbike fairing to the Monster.
brix821
« Reply #1 on: January 07, 2010, 04:56:01 PM »
there were photos of a dss monster with a triumph truxton unit.
GUNS OF BRIXTON
Markus
« Reply #2 on: January 08, 2010, 10:23:51 AM »
Hey Josh. Here's killerniceguy's S2R with a Sharkskinz Thruxton race fairing mounted up. He posted these pics in my thread about mounting a Thrux fairing with the Monster headlight. Don't think he'll mind that I post his pics here. Wink
The mounting holes on both the factory Triumph Thrux fairing and the Sharkskinz fairings line up perfectly with the Monster headlight bracket mount points. Install is really quite easy, although the stock turn signals get in the way and will need to be relocated, or left off entirely while you're on the track.
 Smiley
2000 M966Sie
2007 ST3s ABS
www.eastcoastducaticlub.com
« Reply #3 on: January 08, 2010, 10:34:18 AM »
Fantastic! They'll be left off completely!
Markus
« Reply #4 on: January 08, 2010, 12:12:34 PM »
 waytogo
2000 M966Sie
2007 ST3s ABS
brix821
« Reply #5 on: January 08, 2010, 04:22:31 PM »
the fairing on the priller looks sweet too..  kind of like a snub nosed cbr1000rr kind of thang. could look sweet on a monster.
GUNS OF BRIXTON
« Reply #6 on: January 08, 2010, 04:38:49 PM »
i was thinking the same thing. Not sure if it would be a "direct" bolt up as much as the thruxton one. Going to have to investigate these when "the time is right" which is sometime between getting a ca-cycleworks track tank and going to the track.
killerniceguy
« Reply #7 on: January 09, 2010, 04:59:26 AM »
The Thruxton fairing is as close to a direct bolt up as one could get.  I fabricated a small bracket to attach the bottom of the fairing to the bottom triple to hold it down.  I used a couple pieces of aluminum bar from the headlight mounts to the drilled fairing holes to provide the necessary clearance for the clipons I was running.  With the headlight and signal lights removed and stock bars it should bolt right up.
KNG
S2R800 race bike.  www.ducaticup.com
« Reply #8 on: February 01, 2010, 12:23:32 PM »
FOUND A PICTURE OF WHAT I'M LOOKING FOR:
Just need to track down what its called and where to get it!
Anyone?
killerniceguy
« Reply #9 on: February 01, 2010, 02:00:47 PM »
That is from the S4 Cup race kit, it may have also been called the Monster Cup, I can't remember.  It was run in Europe upon the intro of the liquid cooled monster.  They are impossible to find and often big $$$ if you find one.  There was a guy on the UK monster site with a complete set of the race kit body work including the belly pan, seat cowl and front screen.  I would start my search over there.
Good Luck,
KNG
Anyone?
