February 12, 2025, 02:47:45 AM *
Author Topic: OEM springs  (Read 2402 times)
hackers2r
« on: January 12, 2010, 01:06:11 PM »
I am just curious about the OEM spring rates on my S2R 800.  If anyone has any information it would be appreciated.  Thanks.
hackers2r
« Reply #1 on: January 12, 2010, 01:33:36 PM »
I think I just found a post saying they are .45 progressive rate springs.  Can anyone confirm this?
« Reply #2 on: January 12, 2010, 01:34:42 PM »
front or rear?
« Reply #3 on: January 12, 2010, 01:36:55 PM »
I'd bet money neither front or rear are that light.
hackers2r
« Reply #4 on: January 12, 2010, 01:51:08 PM »
Front fork springs.
« Reply #5 on: January 12, 2010, 01:55:05 PM »
Front fork springs.
If they're progressive there should be two numbers.
« Reply #6 on: January 12, 2010, 02:21:29 PM »
im close to 100% sure that the front is progressive, and its probably too light on the light end, and not enough on the heavy end.
and the rear is around 7.8kg/mm, thats what my s2r1000 spring was suppose to be.
« Reply #7 on: January 12, 2010, 02:32:18 PM »
The front fork springs are progressive on an S2R800.
Rear spring is also.
I've never seen a 'rate' for them.
I'll check one, BRB.
scott_araujo
« Reply #8 on: January 12, 2010, 03:13:12 PM »
What year S2R?  I have an '03 800 Dark (DSS) and I think we share the same non-adjustable Marzocchi fork.  My stock fork springs are definitely progressive and too light for me, no idea what the rates are.  I swapped them for straight rates from RaceTech.
I think we may have the same preload/rebound adjustable rear shock, but maybe not.  We do have different swingarms.  I know my rear linkage is progressive but the spring doesn't look like it is.  I could measure between all the coils to be sure.
Scott
« Reply #9 on: January 12, 2010, 04:02:55 PM »
Just checked an S2R1k fork spring.
It's showing as a .58/.79, with the transition point at about 2.5" of compression.
I wouldn't say that's a laboratory accuracy number, but within +/- 5% IMO.
That transition point occurs about where the forks are halfway compressed.
scott_araujo
« Reply #10 on: January 12, 2010, 07:54:37 PM »
Wow, even the stiff part is pretty soft.  Thanks for some real world info on the springs.
Scott
corey
'06 Tang/Black S2R800
« Reply #11 on: January 13, 2010, 11:28:40 AM »
blows.
can't wait to get my new forks on.
scared as hell of doing it myself... but whatever. worst thing that can happen is they fall off.
« Reply #12 on: January 13, 2010, 11:38:25 AM »
im going to swap an S2R1000 fork onto a 620. brakes and all. even new masters in about 10 days.
i dont mind setting up a cam. or snapping some pics if you need it. its really simple, nothing technical. just bolt off, bolt on.
hackers2r
« Reply #13 on: January 13, 2010, 01:51:55 PM »
Thanks for the info Speedog.  I too am swapping entire suspensions soon and am just wondering what to expect.  I'll post a write-up when it is completed.
