February 05, 2025, 01:56:00 PM *
News: Please Help
Author Topic: Windscreen brace ?  (Read 2260 times)
h_bakken
newducrider
Sunday Ride
« on: January 13, 2010, 06:59:57 PM »
I suppose this is a relatively silly question, but I did a search of the forum and didn't see anything that was applicable -- Is there anything out there to brace the windscreen on an S4RS?  Or do I need to get someone to fabricate something?  If this discussion has already taken place could someone point me in the right direction?
2008 S4RS Tricolore (136/400) Full Termignoni/PCIII/DP Slipper
2005 999R
DarkStaR
« Reply #1 on: January 13, 2010, 07:16:10 PM »
http://www.monsterparts.com/pc/FAIRINGSTAYS/Comfort-Touring/FAIRINGSTAYS.html
http://ducatimonsterforum.org/index.php?topic=15164.msg263287#msg263287
« Last Edit: January 13, 2010, 07:20:16 PM by DarkStaR » Logged
Goat_Herder
« Reply #2 on: January 13, 2010, 08:55:26 PM »
Home made.
Goat Herder (Tony)
mattyvas
« Reply #3 on: January 13, 2010, 09:40:15 PM »
I have these ones and they are great.
Pretty and functional.
http://skycustoms.blogspot.com/
dropstharockalot
Sex-Toy Bludgeonin'
The Teabaggin' Dragon
« Reply #4 on: January 14, 2010, 03:30:47 AM »
Home made.
[img]pic_of_some_awesome_homemade_stuff[img]
Nice!  I'll probably be doing the same thing in a couple weeks...
Did you just hack and bend, or did you measure something out?
'96 M900
Goat_Herder
« Reply #5 on: January 14, 2010, 08:49:06 AM »
I spec'ed it out with carboard stripes for lengths and angles.  Cut it with dremel tool and bend it with a vice and a couple 24" clamps for leverage.
In case you need the dimensions.  Here it is.  The end attached to the fairing needs to be bend at a slight angle to accommodate the shape of the fairing.  You might need to play around to get it right.  Also modification/new bolt is needed for fitting.  $3 with of bolts at Home Depot will do.
I polished the finished braces and painted it with aluminum colored paint for some protection.  Not seen in the pic.
Cheers
« Last Edit: January 14, 2010, 08:50:39 AM by Goat_Herder » Logged
Goat Herder (Tony)
orangelion03
My girlfriend loves my
A Most Magnificent Monster
« Reply #6 on: January 14, 2010, 11:44:47 AM »
Was going to make my own, but those Skycustom pieces are trick!!
I bought a ZG touring screen to fit the stock fairing and will definitely need bracing.
VIVA LA EVOLUCION!!!
S2R 800 '07
« Reply #7 on: January 14, 2010, 01:10:13 PM »
I'm not saying you shouldn't get them, but you might be surprised - the ZG Touring is actually a lot more stable than the stock screen. If I knew and hadn't already bought my PoorDucRider stays, I might have chosen not to. (then, I would've bought the Matrix/Skycustom for bling)
h_bakken
newducrider
Sunday Ride
« Reply #8 on: January 15, 2010, 06:46:50 PM »
Thanks for the links.  I am going to go with the sky customs.  No more wiggles!
2005 999R
