February 05, 2025, 01:48:53 PM *
Author Topic: Fixing a broken turn signal  (Read 1416 times)
orangelion03
My girlfriend loves my
A Most Magnificent Monster
« on: January 14, 2010, 11:39:08 AM »
While I wait to find a replacement, I attempted to temporarily fix a broken rear turn signal.
Turns out that the base of the signal is rubber with a metal threaded boss insert.  The rest of the rubber base has a slightly larger than 1/4" hole running through it.  At first I was just going to find a big  pan head screw to thread into the base, but that would have required enlarging the mounting hole in the tray which I did not want to do.  It occurred to me that some kind of insert might work so I headed off to the hardware store.  Found that a #10-12 plastic anchor was a tight fit in the hole and the  #10 screw with it a good fit in the tray mounting hole.  I did however, have to drill out the threads in the base insert...it can be pressed out and has hex features so it can be clamped in a vise for drilling (I used a 1/4" drill).  When completely assembled, it looks nearly normal, but it will not flex out of the way if hit.   So...anybody got a spare left rear signal?
VIVA LA EVOLUCION!!!
corey
'06 Tang/Black S2R800
« Reply #1 on: January 14, 2010, 11:41:03 AM »
smartass.
orangelion03
« Reply #2 on: January 14, 2010, 11:47:21 AM »
smartass.
Yes.  Yes I am.  cheeky
I had nothing better to do on my lunch hour.  Also cut up a rear fender to make a tidy plate holder.  Pics of that tomorrow.  If you're nice...
« Reply #3 on: January 14, 2010, 12:10:53 PM »
Overacheiver. i used a splint and electrical tape.  Tongue
but i forgot to buy a new one.  Wink
S2R 800 '07
« Reply #4 on: January 14, 2010, 12:30:00 PM »
Shouldn't you fit that #10 screw through the beer tray first, for the turn signal to be on the BIKE?
 Wink
Otherwise well done waytogo
orangelion03
« Reply #5 on: January 14, 2010, 12:46:50 PM »
Now THIS is a prefect example of a smartass Corey:
 Wink
 applause
