April 29, 2024, 09:33:54 AM
So, let's say I wanted a 180 on the rear..
Topic: So, let's say I wanted a 180 on the rear.. (Read 4366 times)
optiato
'07 695
May 29, 2008, 09:23:17 AM »
Would this be possible on a 695 without too much expense?
Omnipotent Potentate
Personal Pretext
Re: So, let's say I wanted a 180 on the rear..
May 29, 2008, 10:17:38 AM »
Define too much expense....
If memory serves me right... Yes it's possible. Some folks did it to 620s and they are about identical to your bike for this job. The details escape me on how much effort and cost was involved though. The info *might* still be around on the DML... but that's if it wasn't burned down by VS
Let me play devils advocate here... Let's say it costs a grand for the whole job + a tire, you could probably get a pair of lighter wheels (same sizes) for not that much more. The bigger rim is going to weigh more. More weight will translate into a feeling of less power in you butt-dyno, because you're asking the engine to work harder to spin upp that greater mass. So 0-60 times will go up - boo.
The larger tire profile and added mass will also make the bike more reluctant to turn in. Slower handling.. boo
Lighter wheels will do the opposite. 0-60 ties would go down (and probably 60-0 too) turning would be easier/faster
So if you're looking at this to be a perfomance mod... it won't be. If it's just a look think - by all means carry on!
onederer
The Anti-Pomp
May 29, 2008, 10:18:17 AM »
yep, you can.
180 tires were designed to fit on a 5.5 inch wheel your Monster came with a 4.5 inch wheel. it will affect the handling a bit. and while people have ridden untold miles with a 180 on a 4.5 it is not optimal.
No moleste el gato spectacular...
optiato
'07 695
May 29, 2008, 10:24:49 AM »
Thanks for both answers. I was pretty sure you could fit the larger tire on the smaller wheel, just trying to figure out the wear/handling difference.
Too much expense means significantly less than just going to a SSS with a new wheel.
Personal Pretext
May 29, 2008, 10:38:14 AM »
oops - I assumed as part of my answer you wanted the 5.5 wheel along with the 180 - were you just askig if you could mount a 180 on the existing 4.5 wheel?
optiato
'07 695
May 29, 2008, 10:44:44 AM »
Well, thinking about different options. But the easiest would definitely be putting it on the existing wheel.
optiato
'07 695
May 29, 2008, 10:52:17 AM »
Ok, DucSea says bad idea.
Would completely throw off the geometry.
loves ze desmodromics.
May 29, 2008, 11:40:50 AM »
Gonna slow down turn in for sure.
May 29, 2008, 01:26:10 PM »
Quote from: ato memphis on May 29, 2008, 11:40:50 AM
jack the rear up 1 inch to comp.
May 29, 2008, 01:29:04 PM »
I say do that anyways, but its the profile of the tire (tyre) that changes, and so you are no longer hitting it at the proper rubber 'angle' when leaned over. You're ok with a little extra rubber, hence the call for the 170s, etc.
Its simply fatter in the middle. Its like a drinking a bunch of beer - after a few you feel like He-Man. After a case, you don't run so fast. Obviously, you won't win any fights if you are skinny, and likewise you won't win any races running a 120 rear tire.
optiato
'07 695
May 29, 2008, 01:36:05 PM »
Hey, I'm skinny and win plenty of fights!
I just want the wider look at the rear tire. I'm happy with the handling...
May 29, 2008, 01:41:17 PM »
Quote from: optiato on May 29, 2008, 01:36:05 PM
Sure you do, Balboa.
I mean if looks are what you are going for, have at it, go nuts, etc. If you are happy with the handling, it ain't gonna handle quite like it did. That whole falling into turns thing? Not so much as before.
The best spent money is not on 'looking fast', but in learning to go fast. Wise money would be spent on a pilot power replacement for what you have and tracktime...
optiato
'07 695
May 29, 2008, 02:11:34 PM »
I agree with you, not willing to sacrifice performance and handling for looks. I flirt with the edges of my tires and like it that way. I *do* like the idea of lighter wheels though... all in due time I suppose.
But I do come from cruisers, and stuffing a bigger tire on them half the time improves stability... so I wasn't sure about loss in handling on the Monster.
Thanks for the info, guys.
A.duc.H.duc.
944 ist sehr gut!
May 29, 2008, 02:45:02 PM »
I don't recommend running a 180 on a 4.5, however a 5.5 inch rear with 180 rubber mounted, should not adversely affect handling much. The weight difference between the 4.5 and 5.5 wheels and the tires is essentially negligable. The bike will turn in a bit slower on the wider rear, but that may not be a bad thing depending on how you ride, and how you like your bike to feel.
Changing to a 5.5 in rear is pretty easy. just make sure you get the cush drive and spacers with the larger rear.
For the record, I ran a 160 on a 4.5 on my m750 for two years and then switched to a 5.5 in rear and 180. I haven't looked back.
Of course I did it in preperation for a 944 motor swap which should be going in in a week or so.
mdriver
Reply #14 on:
May 29, 2008, 03:35:35 PM »
Quote from: A.duc.H.duc. on May 29, 2008, 02:45:02 PM
So for the sake of clarity, and I guess redundancy. All you need for a swap to a 5.5" rear is.
Wheel, cush drive, and the spacers?
Bike Info: 2001 Ducati M750 Dark, 2007 Triumph Bonneville
