February 08, 2025, 06:19:39 PM *
Pages: 1 [2]   Go Down
Author Topic: Request - Chart comparsion between original and Termignoni exhausts on M696  (Read 7676 times)
« Reply #15 on: January 23, 2010, 11:50:38 AM »
unless you luck out and find one for half that price from a wholesale place Evil
jsd2
« Reply #16 on: January 23, 2010, 05:16:04 PM »
I have a 09 696 which I had the Termis installed. If they added power it must be slight because I don't notice it.  It has given the bike a better delivery of the power. There was some flat spots in the power curve and the Termis seem to have made the power curve smoother.  I read about the jump in the rpm limiter but it didn't happen on my bike. It still bounces off the limiter around 8500.   The sound is better even with the baffles in (to loud for my neighbors without) and without it sounds great if you can get away with it. I enjoy the bike more with them Termis mostly because of the improved power delivery.
Jim. Grin
« Reply #17 on: January 23, 2010, 10:52:00 PM »
Jim. Grin
when you turn on your bike does it read "Monster 696 Racing" on the dash?
jsd2
« Reply #18 on: January 24, 2010, 11:44:32 AM »
Yes after I had the work done it started saying racing on the dash when I turn it on.
Jim
« Reply #19 on: January 24, 2010, 12:09:12 PM »
go back and have it checked. everyone else had the higher fuel cutoff
martin696CZ
« Reply #20 on: January 24, 2010, 11:06:02 PM »
The rpm cutoff should be around 10,500 rpm in case of DP ECU? Do you know at which rpm does the standard stock ECU limit the engine revs?
z0mb1e_DUC
« Reply #21 on: January 25, 2010, 02:35:09 AM »
Stock fuel cut off is 8,500rpm.
'09 m696 Dark
craigo
monsters are not trail bikes.
« Reply #22 on: January 25, 2010, 02:48:21 AM »
Monster 696 Stock vs Termis (short)
'nuff said.  waytogo
Pages: 1 [2]   Go Up
