February 09, 2025, 05:17:54 PM
Please Help
916 sbk forks on an s2R monster
Topic: 916 sbk forks on an s2R monster (Read 3235 times)
Labbedds
January 23, 2010, 05:52:26 PM »
will it work?
Last Edit: January 23, 2010, 06:18:16 PM by Labbedds
Wawawiwa
Feral 859
Re: 916 sbk forks on an s2R monster
January 23, 2010, 06:00:51 PM »
http://ducatimonsterforum.org/index.php?topic=17590.msg312805#msg312805
http://ducatimonsterforum.org/index.php?topic=958.0
Last Edit: January 23, 2010, 06:05:50 PM by kopfjäger
Labbedds
January 23, 2010, 06:12:07 PM »
thanks! should have searched first, my apologies
Wawawiwa
Charlief
January 23, 2010, 06:30:50 PM »
They will with some triple work. Keep your eyes open fir a set of monster adjustables. Bolts right in with no problems. That's what I did
Last Edit: January 23, 2010, 06:34:41 PM by Charlief
Labbedds
January 23, 2010, 06:32:34 PM »
true, you mean off an s2r1000 or will s4r/s4rs work also
Wawawiwa
Charlief
January 23, 2010, 06:38:52 PM »
Quote from: Labbedds on January 23, 2010, 06:32:34 PM
as long as the brake set up is the same( not radial) you will have no mods needed. I gkr mine off an old S4.
Yes forks off s2r1000 would bolt right up.
Keep an eye on eBay. Where I got mine.
Omnipotent Potentate
Personal Pretext
January 24, 2010, 04:18:03 AM »
If you manage to get ones off an S2R, S4R (Not the S4Rs with radial brakes) - they will bolt right up and have the benefit of having the same axle diameter as your bike. For best results, you should get the forks done for your weight - if you don't happen to be a little Italian, like I happen to not be.
cduarte
January 24, 2010, 04:44:56 AM »
these forks are fully adjustable, are the correct length and will bolt right on...
http://cgi.ebay.com/Ducati-ST4-ST3-ST2-FORKS-W-TRIPLE-TREE_W0QQitemZ350291621541QQcmdZViewItemQQptZMotorcycles_Parts_Accessories?hash=item518f01f6a5
Charlief
January 24, 2010, 05:45:58 AM »
Quote from: cduarte on January 24, 2010, 04:44:56 AM
They will bolt in but I was told that they are just slightly longer..... I could be wrong as I'm no expert.
Mr Earl
2003 M800 Dark
January 24, 2010, 06:52:58 AM »
One other option is fully adjustable Showas from '99-'01 SS900 (but NOT pre-'99.) Rumored to possess SBK-ish internals (I have no evidence) they have the same geometry as the Monster forks except for length (longer by ~2-2.5".) Proper caliper spacing. I installed these on my M800 and they are sweet. Used the extra length as an excuse to get above-the-triple clipons which have really changed the riding feel of the bike for the better.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
cduarte
January 24, 2010, 07:21:03 AM »
Quote from: Charlief on January 24, 2010, 05:45:58 AM
I had a set of ST2 forks side by side with my old 695 forks, and there is a 3mm difference in length at best, which is negligable.
January 24, 2010, 07:41:36 AM »
Quote from: cduarte on January 24, 2010, 07:21:03 AM
that's what she said.
jim_0068
January 24, 2010, 10:29:11 AM »
Quote from: ducatiz on January 24, 2010, 07:41:36 AM
haha, more like what "he" said
