February 10, 2025, 05:09:04 PM *
Author Topic: exhaust cylinder pipes a mongrel to get off  (Read 1152 times)
Serious Groper
« on: January 25, 2010, 10:23:34 PM »
Have swapped the air filter, ECU and removed Termi slip on mufflers no sweat.
However the 2 small cylinder pipes do not want to budge no matter how hard i try. Have been going at it for 15 minutes with not an ounce of movement.
Any ideas?
Dannog
S4RS
« Reply #1 on: January 25, 2010, 10:29:45 PM »
Heat should do the trick. Of course they are hand to handle when their hot. What until you try to put them on. The rear which goes through the swing arm is a bugger to get our around the shock
Serious Groper
« Reply #2 on: January 25, 2010, 10:31:43 PM »
I did heat them up a little bit with the Benzo but maybe not for long enough. Will give it another shot now and report back.
Serious Groper
« Reply #3 on: January 26, 2010, 11:44:20 AM »
Well i tried and tried and tried. All while dressed in my jocks because the garage was so flipping hot and i was sweating like a dog!
No dice.
Managed to move the bottom of the 2 pipes but thought against it seeing as the top one wasn't budging so what was the point in taking 1 off.
Might just forget it for the time being. Bugger, just paid $300 for all the stock bits which i now can't install LOL.
loony888
"I WAS GOING HOW FAST, OFFICER?"
« Reply #4 on: January 26, 2010, 10:42:32 PM »
have you given them a good spray with CRC OR WD40? seeing as the heat from the exhaust and carbon build up is probably the culprit for the stubbornness a good dose of penetrating fluid may help.
paul.
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
Dannog
S4RS
« Reply #5 on: January 27, 2010, 12:20:37 AM »
I wouldn't 'come of either' if I saw in your jocks in the garage laughingdp laughingdp laughingdp laughingdp
Serious Groper
« Reply #6 on: January 28, 2010, 11:16:45 AM »
cheers Loony, i gave the WD40 a good go but it was no dice. Well i actually got the bottom pipe moving with tapping with a rubber mallet but the top pipe is no dice. I'll have another shot with the WD40 over the weekend and hopefully it can eat away some of the grim like you suggested.  waytogo
Dannog - Me in jocks is about as close to heaven as women can get. The only way closer is me 'not' in jocks  waytogo
loony888
« Reply #7 on: January 28, 2010, 09:55:15 PM »
vomit vomit vomit vomit vomit vomit vomit vomit vomit
i am now scarred for life!
paul. waytogo
more wd40, often will penetrate. give it a tap from time to time and you should be right by monday. it's gonna be wet this weekend anyway
                                              93 888 RS
                                              09 1098R BAYLISS
                                              07 Husqvarna TE 450
                                              01 S4         93 900M
                                              96 748SP
CairnsDuc
« Reply #8 on: January 28, 2010, 11:16:58 PM »
Finally! I don't feel so Weird for Washing my Bike in the Nude  waytogo
In a closed Garage of course, Don't want to offend the neighbors!
FIFO
Doing the latter
« Reply #9 on: January 28, 2010, 11:45:22 PM »
Hey CairnsDuc
Thats just way to much information for me the the mental picture of thats is  vomit vomit vomit
Now Jen Hawkins doin that is a far better mental picture Evil
