M900 motor into xxx chassis?
Started by chris1044, January 26, 2010, 04:56:09 PM
chris1044
First and foremost, I've got plenty of experience to know what goes into a swap - I'm a ptrain engineer for a larg OEM.  So, I don't need the typical "you'll need xxx you fawkin N00b!!!111!_ schooling.  Instead, I'd like to go to school on the 900 motors...
I've done some reading, and they'll basically fit into any chassis with the correct fueling/ignition system, correct (sans the single sided swing-arm models).  I May have a lead on a cheap salvage 620 that's strictly got motor damage...I'd want more power, and the 900 motors can be had fairly cheap.  944 is the hot CID size, but I'm iffy about the investment into that right now.  I've built plenty of motors though and have tons of dyno/flow bench experience...porting of the heads?? Anyone delve into this themself??
They're all carbed, correct?  What about their intake plenum mounting pad - can it be swapped for FI runners?  Custom ECU here we come, but I'm just asking.  Exhausts...what fits from different years?  I can lengthen the main pipe easily, but what about the physical flange section that bolts/inserts into the head? I've read about ignition woes...fixes? common issues?
One thing I want to do is keep this cheap if I do it...a challenge I suppose for a mutt bike
slowkitty
Not much of an engineer here, but if it helps after 2000 the M900 runs on fuel injection, and other models too.
Good luck. Post pics.
Cheers
As slowkitty said, 2000 and after M900 is injected.
M900 engine only went through 2002.
620 exhaust header won't fit a 900.
AFAIK, all 900 headers will fit.
900 engines have both single phase and 3-phase charging systems, you'll want the latter.
Some have close ratio transmissions. I'd recommend getting a wide-ratio one.
Custom ECU is a fairly pricey route.
couple of things.
what is your budget if we can pry? it will help with the suggestions.
and all modern ducati motors fit in all ducati frames as far as motor/swingarm mounts. the key is 2valve vs 4valve for the swingarm. the 2valve motors have the swingarm bearings in the engine case, the 4v have it in the swingarm. you can machine the case to use a 2valve with a 4valve swingarm.
sometimes you have to make changes to the cross member near the intake depending on your configuration.
so essentially you could put a 2-valve air cooled motor into a superbike frame. check out http://ducati-kaemna.de/cms_en/tu_example.htm?&ct=28 for their Demon!
To clarify the swingarm mounting points made above, it's not *exactly* the 2V and 4V that separates the swingarm bearings, it's the chassis:
Monster, SuperSport, SportTouring and SportClassic bikes have the bearings in the engine cases.
SuperBike, Multistrada, HyperMotard bikes have the bearings in the swingarm.
Quote from: Duck-Stew on January 27, 2010, 04:39:38 AM
thanks. i thought the MTS had it but didn't know about the HM. That's why i asked for sanity check earlier. Clearly need one now
darkduc7
i put a m900 carbed motor in a m600. worked nicely, used the aluminum swinger from the 900 and you should use the larger 5.5 inch wheel since your 620 will have the 4.5 inch. that, and different headers as mentioned above, annnndddd yeah thats it.
don't die...don't die...don't die....
chris1044
Quote from: Speeddog on January 26, 2010, 06:04:21 PM
Well then...2000+ motor is what I want if I can get an ECU.  If I can get some hardware that's unlocked, I can tune...have access to some of the best cal engineers in the auto industry, so that's an option.  However, if I can get one with a stock ECU I'll go the route of PCIII likely.
Wide ratio transmissions...translation to years by chance??  Same thing with the 3 phase charging...I'm assuming that this was an upgrade made to later engines, correct?
Budget isn't really an issue I guess, but I'd like to keep it cheap.  If this salvage bike is straight, and I can get a complete motor w/intake for less than 1k, then I'd have roughly 2.5k into it...and I think that'd be worth it.  Plus, I enjoy doing things like this.  There's going to be at least another 500 needed to get it together and tuned I'm sure as well....
I'm I dreaming on costs??  If its something where I can buy a bike for cheaper than I can do a swap, that's obviously the better choice as it'll come with upgraded suspension pieces...perhaps I should focus on finding a cheap 900 already together [cheeky] Think I just rationalized myself out of doing a swap like this...but I would appreciate info on the 900 as I've seen quite a few for cheap.
(Threadjack) Stew, I guess this means it wouldn't be a simple motor swap to take a 1100 from a Mulitistrada and put it into a Monster.
Quote from: Travman on January 27, 2010, 03:39:00 PM
Correct....unfortunately.  (/threadjack)
Porsche Monkey
#10
Quote from: chris1044 on January 26, 2010, 04:56:09 PMI'm a ptrain engineer for a larg OEM.
Do you mean CC size?     ;D[thumbsup]
As far as the transmissions go, the carbureted M900 engines '94-'99 had wide ratio transmissions, injected M900ie '00-'02 had the close ratio.
Dunno what the year crossover was on single-phase to 3-phase.
'00 and '01 M900 had the early-style injection ECU, '02 had the same style as your 620, the IAW 5.9.
chris1044
Quote from: Ducaholic on January 27, 2010, 04:00:59 PM
Yep, told you I was an engineer - most don't know what they're talking about anyway ;D.......guess that's what I get for reading cycle and auto forum stuff at the same time.
Quote from: chris1044 on January 27, 2010, 04:07:01 PM
You can't be an engineer...
they all know everything...and wouldn't admit it if they didn't.
;D
Quote from: Speeddog on January 27, 2010, 04:01:18 PM
One or both of the early years the ecu was injection only with ignition being the old Kokusan system IIRC.
