February 23, 2025, 09:22:53 AM
Missing CODE CARD
Topic: Missing CODE CARD (Read 3970 times)
pespina
Missing CODE CARD
January 27, 2010, 05:49:24 PM »
I recently purchased my second Ducati – a 2008 HM1100 (see
http://www.facebook.com/album.php?aid=154431&id=608540964&l=f63e630439
). Unfortunately, the bike came without:
The small plate attached to the original keys that reports their identification number.
The CODE CARD supplied with the keys reports an electronic code.
Does anyone know what would be involved in getting replacements to those?
Thanks, Pedro
2003 Monster 620S i.e. (sold)
2008 Hypermotard 1100
Duckintime
Re: Missing CODE CARD
January 27, 2010, 09:04:07 PM »
Far as I know, you cant. You should be golden as long as you have the red key at least
mattyvas
January 28, 2010, 01:27:48 AM »
+1
Can't replace either one.
My new web home is now at
www.mattvas.com.au
MattyVas Flickr Photos
OzMonsters Flickr Photos
swampduc
'99 996, '07 S2R1000,'08 1098s, '12 1199s
January 28, 2010, 04:43:16 AM »
Quote from: Duckintime on January 27, 2010, 09:04:07 PM
I thought they discontinued the 3 key system in 07. That's why the code card is necessary.
Respeta mi autoridad!
DesmoDingbat
January 28, 2010, 06:30:40 AM »
The key card is only used in the case that you lose your keys. The dealer can use it to rape you for a new key $$$
Either way you can get your key cloned (from red or black) at most locksmiths. Ebay has keys for $10-60 depending on whether you want original, Hong Kong or China...
$56.99...eBay item # 200432146946
$14.99...eBay item # 160387477960
$9.99...eBay item # 280347937058 (no transponder, just a replacement for broken key)
I finally found it, moved it, and now I can't find it again!
pespina
January 29, 2010, 04:36:32 PM »
Thanks for the advice.
In 2008, the HM came with only two black keys. I see that I can get a blank key with transponder and I imagine that a locksmith can cut it as per the other. But,
Don't I need to program the transponder so the CPU will recognize it as legit?
Dont I need the electronic code in case that the Immobilizer gets accidentally blocked?
Thanks
WhiteStripe
Monster Addiction
February 03, 2010, 04:46:05 AM »
If the immobilizer get initiated for some reason you need the Code CARD to unlock. You enter this code using the throttle.
My previous owner lost it so i did a bunch of research and found without it you are basically SOL. You can get the ECU reprogrammed, or a new ECU that can get you around this. Subsequently, the PO found the code card so i quit there. TONS in the archives about this.
Good luck
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
krista
... does she have a
ducati addict
February 04, 2010, 08:00:40 PM »
It's my belief that the code card has the RFID of the red key on it. I have yet to personally see one start an immobilized bike.
For anyone that doesn't have a red key or code card, just go buy a "blank" key off eBay and get the one or two locksmiths in your closest major city who actually can "clone" to clone it and then lock it away in your safe place. So that
it
can get lost...
Krista Kelley
autist formerly known as chris
official nerd for
ca-cycleworks.com
