February 05, 2025, 05:03:03 PM
Ditching the digital dash
Topic: Ditching the digital dash (Read 2426 times)
wingnut
February 01, 2010, 07:52:45 AM »
Does anyone know of a way to ditch the digital dash on the 1100 to go back to the old needle speedo & tach?
superjohn
Re: Ditching the digital dash
February 01, 2010, 10:09:40 AM »
With the immobilizer, it would be hard and costly. I think Spidey did something similar and basically took the guts out of the digital dash and ran it to a box under the seat, and had a duplicate set of gauges spliced in that was mounted on the dash.
http://www.ducatimonster.org/featured/2007july/featured0707.html
I wanted to do this as well and mount a Motogadget unit but decided it was way more trouble than it was worth.
wingnut
February 01, 2010, 10:49:11 AM »
Is it more feasible if I were to do away with the immobilizer? I'm up against "costly" anyway since I broke the lcd on my dash and have to replace the entire thing. If I have to replace it, I'd rather replace it with something I like (like the motogadget). Is doing away with the immobilizer even an option?
S2R 800 '07
February 01, 2010, 10:55:32 AM »
I hope you can and will do this
It will make the 696/1100 better looking. Old headlight and fairing as well?
wingnut
February 01, 2010, 11:22:20 AM »
The old headlight was going to be my next move.
superjohn
February 01, 2010, 12:32:10 PM »
I think the only way to get rid of the immmobilizer is to replace the fuel injection system as the ECU checks the immobilizer to see if it's ok to work.
wingnut
February 01, 2010, 01:59:07 PM »
Could there be a way electrically to "trick" the ECU and bypass the immobilizer?
yotogi
February 01, 2010, 02:12:27 PM »
I don't think that anyone has figured out how to flash the 696/1100 ECU yet. People have just finally figured out how to do it to the older monster ECU so it may take some time.
Once done, you can disable the immobilizer. Now, removing the gauge cluster is perhaps another thing in addition to this so don't think that alone will get you there without being sure first!
