Show off your backup power thread
Started by ducatiz, February 08, 2010, 10:08:43 AM
Quote from: ducatiz on February 08, 2010, 04:38:30 PM
electric or gas?
my gas furnace fan only pulls about 3A
Gas
How are you measuring it?
electric or gas?
The blower?
I think not.
mine is oil BTW.
Quote from: mitt on February 08, 2010, 04:43:09 PM
Gas
I open the filter door and voila, there is a sticker on it.
Quote from: ducpainter on February 08, 2010, 04:43:36 PM
The blower?
I think not.
that's nothing new... ;D
Quote from: ducatiz on February 08, 2010, 04:45:46 PM
not much of a blower. :-\
Quote from: ducatiz on February 08, 2010, 04:40:09 PM
what the hell kind of fridge is that?
I have a brand new LG fridge (the french door model).  it pulls 6 A on running and only 7.5 on startup.
i know the old old school fridges pull hard on startup, but sheehs, 2 to 20? wtf?
You would be surprised at how high real peak current is on electrical motors.  It doesn't last long it is only 1 or 2 AC cycles, each cycle is 16.67 milliseconds.  Circuit breakers for example set their mag trip levels from 3 to 10X their handle rating.
I brought a high end true rms peak capture fluke meter with hall current sensor and a tektronix scope home to capture my data.
Here is a chart of my household loads and other misc info I found for anyone who is interested:
http://sites.google.com/site/mittelstadtc/Home/engineering/generators
Quote from: ducpainter on February 08, 2010, 04:46:59 PM
it's a trane high efficiency system, <6 yo.  works fine for our house which is just under 3000 sq ft.
Quote from: mitt on February 08, 2010, 04:48:51 PM
i don't understand why my 1000w generator isn't grenading then...
6.1A fridge and 3A furnace fan.  generator has 1200w peak for i don't know how long.
3A might be what it says, but not what your furnace is using when pulling air.  My furnace says 1/3HP, so about 250W, so about 2A, similar to yours, but it pulls more like 600W, about 5 A when running.  There are a few other loads in the furnace that are in that figure too.
Quote from: ducatiz on February 08, 2010, 04:51:00 PM
Where did you get 6.1A for the fridge?
Quote from: mitt on February 08, 2010, 04:53:41 PM
I'm wondering what voltage they're using?
Quote from: ducpainter on February 08, 2010, 04:58:20 PM
I believe I know why your generator is handling it.
i ~know~ why.. the fridge and the fan are <1000W operating and <1200W startup..  AFAIK
you guys are convinced my fan is pulling 5-6 amps and i can't believe it.
Quote from: ducatiz on February 08, 2010, 04:59:57 PM
nope...
your generator and your utility is delivering more than 115 volts.
P=IE...
measure your supply voltage...and
do the math counselor
Quote from: ducpainter on February 08, 2010, 05:01:43 PM
nope...
P=IE...
i haven't checked the generator, it might be putting out 120, but i doubt more than that.  can't be drastically more amperage though.  it's got a voltage regulator on it (yeah yeah i know, they go bad)
