DP rear sets (brake lever return spring)
Started by dansamp, February 08, 2010, 02:18:20 PM
dansamp
I picked up a set of these rear sets
http://www.store.commoto.com/ducati-monster-adjustable-footpeg-dssa-p-279.html
and am wondering if anyone has any experience with installing them
I am wondering if there is a return spring available separately , ???
any info would be greatly appreciated
Thanks
Dan......
2001cromo
I've got them
They install easy.
They move the foot closer to the clutch cover (forward).
They don't have a brake light switch, so either you leave the rear brake light switch off, make your own or use a pressure switch at the banjo.
They don't need a spring, but if you wanted to you could put one on the master's pushrod itself. Again, it's not needed and returns fine.
Getting replacement parts can be a PITA.
