January 02, 2025, 10:18:28 PM
Please Help
starter motor delay
Topic: starter motor delay (Read 1936 times)
oliver dicicco
starter motor delay
May 29, 2008, 09:25:50 PM »
Hi I'm new to the group and to ducati ownership. I got a '98 monster 900, when I hit the starter button there is a lag of about one second before the starter kicks in. I've got a new battery and starter solenoid, all the contacts have been cleaned and everything is tight. When I use a jumper cable between the battery and starter it kicks in immediately. Is the lag a normal condition, or should I try heavier guage wiring between the battery solenoid and starter. Thanks
Desmo Demon
Re: starter motor delay
May 30, 2008, 04:25:45 AM »
Quote from: oliver dicicco on May 29, 2008, 09:25:50 PM
This is the next thing I would do. Both of my '98 ST2 bikes had that problem and it was cured by installing larger diameter starter cables. I believe I got the cables from Powerlet or something like that.
IBA #32735
May 30, 2008, 07:08:53 AM »
Chances are good the connection at the starter has high resistance. A voltage drop test over the connection should reveal if this is the problem. You should have less than a .2 volt drop at that connection. While you are at it check all the connections for voltage drop, battery, solenoid, and ground. If you need to clean the connection at the starter be careful. The lug coming out of the starter is very delicate.
If you don't know about voltage drop testing, I googled and found this link:
http://www.aa1car.com/library/voltage_drop_testing.htm
oliver dicicco
May 30, 2008, 07:16:32 AM »
Thanks for the info, I'll check out the voltage drop, fatter cables will probably help too.
May 30, 2008, 11:42:19 AM »
Quote from: oliver dicicco on May 30, 2008, 07:16:32 AM
Yes, they will, but as long as all connections are clean and solid with a good battery the bike should start fine.
