April 28, 2024, 08:25:52 PM
Statler
Help me find my thesis; lost in microsoft word?
Topic: Help me find my thesis; lost in microsoft word? (Read 4590 times)
Alex
2000 M900ie
Re: Help me find my thesis; lost in microsoft word?
Reply #15 on:
May 30, 2008, 11:43:29 AM »
My word setting state that it autosaves a recovery file every ten minutes, but the recovery folder doesnt have the file I worked on for two hours.
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting half-open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded), CRG clutch/brake levers.
derby
Reply #16 on:
May 30, 2008, 11:57:32 AM »
Quote from: Alex on May 30, 2008, 11:43:29 AM
did you try this?
Quote from: derby on May 30, 2008, 07:51:55 AM
if it's not in the normal temp directory, it may be in the temporary internet files.
look in %userprofile%\Local Settings\Temporary Internet Files
look for a folder name that begins with OLK if you're using outlook.
where are you downloading it from? what are you downloading it with?
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
m0t0g0th
.:GoneFeral:.
Reply #17 on:
May 30, 2008, 12:00:15 PM »
if you hit save, and it was allowed, then open the version that is attached to the e-mail and see if you recognize it as the "new" version.
my system doesn't allow this to happen, but it has happened to others.
A red traffic light means:
Incoming missiles
Stop
You win! Speed through the intersection to claim your reward!
Alex
2000 M900ie
Reply #18 on:
May 30, 2008, 12:07:31 PM »
Couldnt find it in temporary internet files either. I got it from my gmail account. I figure I must have hit "open," instead of "save" when I started. Still though, it must have been going somewhere...
Im sure the version attached to the email is still the old version.
derby
Reply #19 on:
May 30, 2008, 12:36:44 PM »
Quote from: Alex on May 30, 2008, 12:07:31 PM
yup... it shoulda been in %temp% if you just saved it from word. sorry, mang.
-- derby
'07 Suz GSX-R750
click
here
Alex
2000 M900ie
Reply #20 on:
May 30, 2008, 02:13:17 PM »
Well, I've given up and am now working on re-writing what I did. Oh well. I'm absolutely positive it will turn up as soon as I'm done, but that's just how things work.
Thanks for the help.
crazy bike girl
aka msincredible
Reply #21 on:
May 30, 2008, 02:20:16 PM »
Ah well, hopefully the rewrite will go quicker and be even better than the original. good luck!
photo FAQ
oldjackbob
Reply #22 on:
May 30, 2008, 03:32:16 PM »
Not to say I'm perfect (or even remotely competent
), but I decided long ago to do frequent saves, and if I'm working on a really important file, from time to time I'll save it as a different filename, and then periodically swap back and forth between the two filenames during my work session -- that way, if something disastrous happens to the file I'm working in, I have a not-too-distant copy in the other file.
What "disaster" could possibly happen, you ask? Well, in the past twenty years (yeah, I'm old) I've had a couple or three occasions where I lost power during a disk write, resulting in a complete loss of data -- in a critical file. On those occasions I was REALLY glad I operate the way I do!
Just trying to offer a heads-up.
"You can't build a reputation on something you haven't done." -- H. Ford
knightrider
Reply #23 on:
May 30, 2008, 04:18:39 PM »
in word 2007, click on the circle in the upper left, goto word options in the lower bar. now goto save, there are 3 file locations there, check the autorecover file location, default file location, and also check the server drafts location.
word 2007 automatically saves every 10 minutes to an alternate location.
hope this helps.
Last Edit: May 30, 2008, 04:20:12 PM by knightrider
1994 M900
eyeboy
some say, he eats raw bacon for breakfast...
Reply #24 on:
May 31, 2008, 09:36:28 AM »
i think the only thing left would be to search for all files and folders modified in the last day or so... whenever you edited the thing... and them sort the results by date modified, you should get something if it saved a copy at all... word keeps all it's changes and revisions inside the document but unseen unless you tell it to track revisions or something... if you can find it you could open it in a text editor like notepad and it should have the revisions you made in it
BTW, this is a cautionary tale for you word users... just because you delete it doesn't mean its gone... it's just hidden sometimes.
good luck!!
Quote from: ducatizzzz on October 23, 2008, 04:13:21 PM
Obfuscate! Obfuscate!
Gentlemen, you can't fight in here, this is the War Room.
There is nothing noble in being superior to some other man. The true nobility is in being superior to your previous self. And in bacon.
