April 28, 2024, 06:56:57 PM
Statler
Help me find my thesis; lost in microsoft word?
Topic: Help me find my thesis; lost in microsoft word? (Read 4589 times)
Alex
2000 M900ie
May 29, 2008, 10:23:33 PM »
I am going nuts. I just spent a few hours updating my thesis after downloading it from my email. I was sure I saved it, but when I went to email myself the updated file, it was just not there.
I've searched like crazy, and it's nowhere! WTF!!!!
Is it possible that microsoft would really let me edit a file for two hours that was "read only," or just delete it without a trace afterwords?
What should I do? (please don't say get a mac. that's not helpful)
Aftermarket: RoadRacing modified under-engine exhaust, revalved 996 forks, ProCutting half-open clutch, CC triple and pressure plate, 999 clipons, BMC filter, CRG-LS mirrors, PC3, Rizoma rearsets, heated grips, +2 teeth in rear gearing, Veypor VR2 computer, MBP collets, Yoyodyne slave, Galfer waves front and rear, misc CF (mostly faded), CRG clutch/brake levers.
darylbowden
Administrator
Re: Help me find my thesis; lost in microsoft word?
May 29, 2008, 10:59:07 PM »
Are you sure you didn't choose open file instead of download file? Re-download the file now from your email and see if the changes are there. This exact thing happened to my gf a few weeks back and I was shocked, but it actually worked.
If that doesn't work, try doing open recent -> your file. Then save to desktop or wherever.
Hope that helps you.
55Spy
May 30, 2008, 12:12:07 AM »
I assume you did a search with the filename. and that you opened Word up and went to recent files to check for it
roy-nexus-6
May 30, 2008, 01:35:39 AM »
searched 'recently modified files'?
May 30, 2008, 03:31:15 AM »
Do a search for all files & folders. Make sure you're searching all drives. In search string, put: *.doc
That will pull ANY file with the .doc extension which is the Word extension ~
JM
mihama01
May 30, 2008, 05:15:08 AM »
Open the Run... from the start menu and type the command %temp%
Two % with the word temp in between. That will open your temporary folder, look for it there.
Thats where Outlook saves attachments before they are opened by Word etc. there is good chance it is still there.
Alternatively, look at the recent items from the MS Word File menu.
Red S4Rs, Tokyo
Sause
May 30, 2008, 05:17:44 AM »
what version of windows? If XP then go to
C:\Documents and Settings\"Your Profile Name"\Application Data\Microsoft\Word
if it's not in there then its gone more than likely
You may need to allow the viewing of hidden files.
http://www.microsoft.com/windowsxp/using/helpandsupport/learnmore/tips/hiddenfiles.mspx
Good Luck!
2000 Ducati M750
Ohlins Rear
Clip On's
Carbon High Mounts
1999 KTM EXC 250
2003 M1000s
May 30, 2008, 06:18:37 AM »
Try opening the original attachment again from email.
In word, go up to 'save as'
That will show you the default temp directory word will save it to.
Now go to that directory in file explorer, and find the file you modified by date or size or something. The name will probably be something completely arbitrary, like " ~7001291.doc "
You may need to copy the file out of the temp directory and rename it for word to open it.
homepage
http://sites.google.com/site/mittelstadtc/
Alex
2000 M900ie
May 30, 2008, 06:28:07 AM »
I think I did just hit open by accident instead of downloading it. Still though, I would think it should save when I hit save...
This is in Vista, on word 2007. I don't use outlook, the file came from my gmail account.
The *.doc search did not find it
The %temp% search did not find it
hidden files are shown
as far as I can tell, the temp directory is empty... Maybe I looked in the wrong place? When I hit save from a file I open out of email it offers me my default save directory, not some secret temp place. Like I said though, the %temp% area I found did not have it.
Agir
May 30, 2008, 06:49:38 AM »
Try the same thing again....open it from E-Mail (just don't waste time on editing) and then hit "save as" - see where this is pointing to...
derby
May 30, 2008, 07:51:55 AM »
Quote from: Alex on May 30, 2008, 06:28:07 AM
if it's not in the normal temp directory, it may be in the temporary internet files.
look in %userprofile%\Local Settings\Temporary Internet Files
look for a folder name that begins with OLK.
-- derby
'07 Suz GSX-R750
click
here
for info about my avatar
darylbowden
Administrator
May 30, 2008, 08:49:53 AM »
Word 2007 uses .docx no? Do a global search for *.docx as well.
crazy bike girl
aka msincredible
May 30, 2008, 08:55:53 AM »
How about a search for all files modified in the last day, and make sure View Hidden Files and Folders is turned on.
photo FAQ
2003 M1000s
May 30, 2008, 09:46:39 AM »
Quote from: Agir on May 30, 2008, 06:49:38 AM
+1 - that is what I said above.
homepage
Alex
2000 M900ie
Reply #14 on:
May 30, 2008, 11:29:53 AM »
DocX was no help, and like I said above, when I download it again and hit save as, it just points towards my regular documents directory.
I've done every sort of search I can think of, hidden files are unhidden, searched in file contents of all drives. This is crazy. Why would it say it was saving, then just lose it?
One thing I should mention: I tried the re-downloading the file and saving it thing last night (one of the first thing I thought of), and the first time I tried to save a file, it said "Error, windows cannot save this file normally. Would you like to save it to your rescued document directory?"
I said no, since I thought it was talking about the new file. Maybe word had realized the old file never saved and ran across it, and was offering me a chance to retrieve it. Unfortunately, if that was the case, there was no way for me to know that it might have been my old file.
