696 swingarm info needed
Started by TAftonomos, February 14, 2010, 06:23:12 PM
TAftonomos
Trying to decide between using a 999 05+ swingarm, or a 696 swingarm on this track bike project thats stuck in my head.  I also could go with a s*R arm, but I want something different.
I'm assuming the 696 arm will bolt up to a 2v motor, wheras the 999 one will require some work (bearings in case, bearings in arm).
Anyway, could someone measure the length of a 696 arm from the pivot to the axle plates?  Could you weigh it as well?
Thanks!
danaid
  The 696 shock is mounted to the left side of the swing arm and corresponding sub frame point, I believe different than the previous models.
11' 1198SP  Black
09' 1100S    Red
another thing i'll do when i get to the shop this week. will try to give you full dimensions. do know that it's longer than the old SS swingarms ;) had checked the SS swinger as an option for the rebuild but it would have been a decidedly different wheelbase
he is right about the shock though. it's offset to the left side about 50% between the center line and the outside, but i'll give you exact points later.
TAftonomos
Shock being offset is no big deal.  I'm going to use a SBK frame and will have to add a mounting point for it anyway. [thumbsup]
TAftonomos
Anyone out there have a sec to do this?
I need the rear width to see what wheel I can use
Axle diameter
And length from pivot to axle.
please please please :)
z0mb1e_DUC
axle is a 25mm, i know a 5.5inch wheel will fit, but not sure of actual measurement.
'09 m696 Dark
