February 10, 2025, 05:00:23 PM *
Author Topic: Water in the air intake  (Read 1215 times)
Vinnnn
« on: February 15, 2010, 09:42:48 PM »
I know how all of you parents feel when your kids continually disappoint you..
Installed the new r/r unit (one million thankyous to everyone who helped!), new battery, rewiring, etc.
Also did an acid cleanup using the bicard soda method suggested by mmick, which again worked brilliantly.
After doing all of this I start the engine 3 or 4 times and it works perfectly.
I give the bike a victory scrub, hose it down, andd
nothing. Wont kick over at all. The starter motor spins, but it doesnt start. It backfires though.. It spurted fire about a foot out of the right exhaust and made a noise so loud that I can still taste petrol.
What I think has happened is when I popped up the fuel tank and gave the underside a spray (to clean off the acid) I have gotten water in the air intake.
Any ideas on what I should do?
FIFO
Doing the latter
« Reply #1 on: February 15, 2010, 10:00:30 PM »
Sounds like it could be wet ignition. Undecided
try wd40 on the plug leads and coils to dry out the water.
Also if you think you got water in the air intake
remove the air filter and dry it.
remove the spark plugs and check for water on them and crank the engine over for a while  to expell any water. Cheesy
rendang
« Reply #2 on: February 16, 2010, 12:18:11 AM »
   Always really carefull when I wash mine, put some plastic bags over the instruments, a plastic cap over the ignition and keep the rinse spray to an absolute minimum. I can imagine your frustration atm, but one by one, you get the problems solved, then you really appreciate the good times.
S2R800,    0    , 750 GT, Rickman Honda, 450 'Silver Shotgun", 750 Sport, 250 Mark 3, Kwaka 500 triple.
monstermick58
« Reply #3 on: February 16, 2010, 01:46:22 AM »
+1  waytogo
