February 23, 2025, 05:52:52 AM *
Author Topic: Too low.... crikeys.  (Read 1108 times)
ryandalling
Trade you my milk for your Ducati...
« on: February 17, 2010, 03:24:03 AM »
So, I bought one of them fancy lowering links for my wife's 620... lowered the bike and then lowered the forks too.... the bike is now so low that I have issues with speed bumps and pot holes.... argh.
She does fit the bike though... I think I might have to shave the seat instead... then raise her back up a bit....
Anybody have an idea on the minimum clearance?
Confused rider who doesn't know what he is even riding at the moment. (2012 URAL GearUp, 2012 Ninja 250 Racer, 1969 CB175 Racer)
2003 M1000s
« Reply #1 on: February 17, 2010, 04:21:09 AM »
Tough question - I have scraped hard parts on a stock height m1000 going over a small crest at the right angle at slow speeds.  I don't think there is a right answer, depends on where you ride and what you want for a trade off.
Omnipotent Potentate
Personal Pretext
« Reply #2 on: February 17, 2010, 04:33:21 AM »
YOu might look up posts by MangledBug and Industrialgrrrl. Both are not very tall, and have done a lot of custom work to their bikes. One of MangledBugs posts, (might be on TOB though) was a step by step on how to make a shaved down, gel seat
Online Online
« Reply #3 on: February 17, 2010, 04:35:19 AM »
http://ducatimonsterforum.org/index.php?topic=2513.0
Personal Pretext
« Reply #4 on: February 17, 2010, 05:40:07 AM »
^^^ Yeah, what he said.
MotoCreations
« Reply #5 on: February 17, 2010, 05:59:39 AM »
Remember to check the front tire at full compression to make sure it doesn't hit the engine or oil cooler.  Easier to do now then when she does from high speed.
What is hitting is your exhaust -- two options: raise it via fabrication so it is closer to the engine and then ceramic coat the pipe to offset the heat factor.  Or build a custom exhaust completely and route it down the left (or right) side of the engine ala my DesmoDevil series.  My engine case / oil filter is where your exhaust is at now.
Also when lowering a bike, check for kickstand  height (need shortened?) and cornering clearances (ie: leaned over) of kickstand (when up), footpegs and exhaust transitioning to exhaust cans (ie: part that sticks out).  You will tend to get more "sparks" when leaned over cornering as you get lower.
