February 23, 2025, 05:54:37 AM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Navy Base Decals  (Read 3447 times)
freeclimbmtb
From Zero Member to
« on: February 17, 2010, 08:39:55 AM »
Im sure there has to be someone else out there whos dealt with this.  I work at a naval base and they require all vehicles (including bikes) to be registered and display stickers.  The hitch here is I want to be able to take my bike to work, but I have absolutely zero interest in polluting my new bike with those stickers :'( I was thinking about some kind of a plate attached to the trellis with hose clamps (http://www.summitracing.com/parts/FRA-900956/) or possibly a plate that would utilize the front fender bolts (would need to have a standoff and use a longer bolt)
Anyone found anything that works?
2011 Monster 796 ABS
Punx Clever
« Reply #1 on: February 17, 2010, 08:51:55 AM »
On the classic monsters the headlight mount bolts up to the lower triple in a way that it would be easy to attach a plate for vehicle stickers there.  Two bolts, swap in swap out in 10 minutes probably.
2008 S2R 1000 - Archangel
Omnipotent Potentate
Personal Pretext
« Reply #2 on: February 17, 2010, 08:55:31 AM »
Do they stipulate where they need to be, front vs back etc? Someone make a little plate out of sheet aluminum that they just attached to their license plate to display a college sticker... Couple be a solution to your problem.
On DSS monsters, it's easy to mount a plate between the frame and rearset. I've got one that I picked up at a HD shop to display my states safety inspection
« Reply #3 on: February 17, 2010, 09:13:25 AM »
most bases require it being permanently affixed to the bike. ie to the frame or fork.
so the removal would destroy the sticker. if you put it on a removable plate you defeat that purpose.
« Reply #4 on: February 17, 2010, 09:56:54 AM »
stick it to your rear tire.
Pip
BRRAAAAIIINNNNSSSSSSS!!!!!!!
ROLL TIDE
« Reply #5 on: February 17, 2010, 11:19:33 AM »
The solution being stick it on something that looks permanent, but is easily removable.
teddy037.2
« Reply #6 on: February 17, 2010, 11:31:59 AM »
I'm far too lazy to check out TOB for it, but someone came up with the idea of rolling Al sheet to fit around the fork tube, in between the triples, and mounting the sticker there.
In fact, I think it was urban's idea...
The Bacon Junkie
I have a Bacon Wrapped
Save the brass...
« Reply #7 on: February 17, 2010, 12:00:56 PM »
My buddy (Air Force Reserve) put his on his steering tube. Couldn't really see it from ten feet, put totally readable from up close.
Save the Brass...
Punx Clever
« Reply #8 on: February 17, 2010, 12:05:04 PM »
Aluminum sheet around the fork... could just get a thin-walled aluminum tube cut to fit just right between top&bottom triples with some rubber on the inside or ends to prevent vibration.
duccarlos
« Reply #9 on: February 17, 2010, 12:06:12 PM »
Tattoo it to your forehead??
CMDRDAVE
'01 Yellow M900i.e. '98 Yellow 748
« Reply #10 on: February 17, 2010, 12:20:13 PM »
I cut a small metal plate to just the right size for the stickers, drilled a hole in each corner, and spray painted it the same color as the frame (black).  Used black zip ties to attach it to the upper and lower frame tubes just aft of the steering head.  Works great, can be removed in 15 seconds, no permanent marks, never had anyone question it.
Insert witty comment here-->
loves ze desmodromics.
« Reply #11 on: February 17, 2010, 01:12:09 PM »
Shit, there is a part for this. Seriously. Made from carbon. Hold on. [off to rummage through internets]
« Reply #12 on: February 17, 2010, 01:21:19 PM »
"Decal Plate"
Found here, $35:
http://www.feathercarbon.com/cf_parts/sport_bike/ducati/ducatipage.htm
Airborne
Crash n' Burn
Monster S2R 800 - ALL BLACK
« Reply #13 on: February 17, 2010, 02:10:57 PM »
put mine around the fork. hardly noticable.
freeclimbmtb
From Zero Member to
« Reply #14 on: February 17, 2010, 04:42:38 PM »
ato memphis...EXACTLY what I was looking for.   I also know a lot of guys put it on the swing arm where the chain kinda masks it...
Thanks for all the input!!
Pages: [1] 2   Go Up
