blazer eating spark plugs
Started by VisceralReaction, February 19, 2010, 10:56:41 AM
VisceralReaction
Got an 84 K5 Blazer that eats plugs  ???
It runs great for about 6 months and then I have to swap out the plugs on it.
Does anyone have an idea why it would do that?
Quote from: VisceralReaction on February 19, 2010, 10:56:41 AM
define eating...
electrode erosion...
fouling...
what?
angler
What's wrong with the plugs?  Burned off tips, covered in black oil or what?
Does it also eat oil?
<edit>
bit slow on the draw today....
Because it's a chevy?  ;D
We need more symptoms.
VisceralReaction
No fouling, it's erosion of the side electrode.
Doesn't burn oil
Quote from: VisceralReaction on February 19, 2010, 11:14:40 AM
Doesn't burn oil
Always used to be indicative of a reaction with lead in the fuel.
Since there isn't any lead I'm thinking corrosion.
Does the rig sit a lot?
angler
#6
Cool NGK diagnostic chart
http://www.ngksparkplugs.com/tech_support/spark_plugs/faqs/faqread.asp
They list oxidation/corrosion, lead interaction, overheating.
Even better pictures and diagnostics
http://www.autohausaz.com/html/spark-plugs_spark-plug-wires.html
VisceralReaction
very cool, thanks. On some there is a huge carbon buildup.
One other it looks melted, I know this is worthless without pics but I'm at work.
I'll get pics when I can and revisit this unless anyone might have ideas to look at
VisceralReaction
yeah it used to sit all summer for some reason and was only driven in the winter
angler
Do you run a lot of fuel additives?  Do you have problems with detonation (pinging)?
I'm going with poor quality ethanol fuel.
VisceralReaction
Quote from: angler on February 19, 2010, 11:23:41 AM
According to the NGK chart its melting. Why would there be overheating
Quote from: VisceralReaction on February 19, 2010, 11:37:25 AM
are they the right plug?
Oldfisti
I once had an 84 K5 and from what I remember the carb was jetted way lean for emissions.
Add crap E-10 fuel to the mix and I could definitely see it running even leaner and melting plugs.
VisceralReaction
That i am not sure of. I'll have to check. ^
This is a new to me rig and trying to fix it's issues.
But hey it was free
