howto sand shims
Started by SeaLander, February 19, 2010, 12:02:32 PM
SeaLander
I have 400 and 600 grit metal sandpaper and a flat surface. Can you describe the process of sanding shims?
Thank you!
get some 220 and get back to me. ;D
seriously...those grits are unnecessarily fine for the job.
Ddan
Get a diamond stone.  After you get back to Nate, he'll tell you to use a figure 8 motion to avoid creating an uneven surface, and turn the shim occasionally.  You'll have to take a few measurements to get an idea of how fast you're removing material.
Ducati Monster Forum at
www.ducatimonsterforum.org
Quote from: Dan on February 19, 2010, 12:55:53 PM
actually I don't use a figure 8.
I push straight ahead and rotate the shim 900 every other push.
I find it to cut faster and still maintain a flat level surface...but I use 220 paper.
Ddan
Quote from: ducpainter on February 19, 2010, 01:00:45 PM
;D
Well.  I do the same thing, but I was always told to do the figure 8 thing, so....
The stone is way easier to use than paper, and they last forever.
Quote from: Dan on February 19, 2010, 01:07:11 PM
;D
I never prescribed to the do as I say theory.
I want everyone to have the opportunity to do it wrong like me. ;D
64duc
  the way I've been doin it since 1966.    [bow_down]
94 M900, 64 Diana 250
scott_araujo
Never thought of using my diamond stone, that's a great idea.  It's much smaller and easy to handle than my 12" square marble tile and sand paper.  Almost any pattern should work if you rotate the shim often and don't press on one side of it excessively.
Scott
teddy037.2
we were taught the figure 8 for not flattening round things, like valve balls
I do the push and rotate for anything flat, like shims
uclabiker06
Always something new to learn around here.   [thumbsup]
2006 S2R
2009 Smart
2001cromo
I'm curious, has anyone noticed any difference in the actual size when measuring a now "hot" freshly sanded shim?
Quote from: 2001cromo on February 22, 2010, 03:53:48 AM
I don't move fast enough to get them hot. ;D
2001cromo
Quote from: ducpainter on February 22, 2010, 03:55:05 AM
LOL, but thankfully your wit is still quick   ;)
Quote from: 2001cromo on February 22, 2010, 05:12:41 AM
Seriously, I don't think it's an issue.
If you're concerned you could always use some oil on the wet/dry as a lube.
It would get difficult to hold on to the things though.
scott_araujo
I usually use WD-40 on wet/dry, no problem holding on to the shims.
Scott
