Bike cover in a garage?
Started by Adamm0621, February 21, 2010, 05:06:21 AM
Adamm0621
On my first Monster I had an all weather cover because I didn't have a garage.  Now I have a garage and was wondering how many of you cover your bike even though its in a garage?
2010 Monster 696 Dark
LA
I don't now, but I have used a cover in the garage.  It keeps the dust off. My covers rotted away and I didn't replace them.
When outside if the cover is left on for long periods in damp environments it traps moisture.  On good days one should take the cover off to let the bike breath and dry well.
And of course, if you cover the bike inside the garage, you will be deprived of seeing it as you pass though the garage.
LA
I cover mine in the barn sometimes if the bats are sleeping overhead.
It saves cleanup.
nicrosato
I keep mine covered in the garage because of the dust. This year is worse than usual, since we are re-doing the basement (=much more dust) and the garage leads directly into the basement. I do uncover from time to time to check the trickle charge connections and , well, just look at it.
Nobody said that I did. Everyone says that I would.
justinrhenry
i don't cover mine in the garage.  it doesn't sit long enough to get dust.
_____
2013 Honda CB1100D
2006 Honda ST1300
2003 Ducati Monster 620ie
I don't cover mine because dust is a crucial component of the protective filth layer.
duclvr
Quote from: justinrhenry on February 21, 2010, 06:26:04 AM
+1
The garage *is* a bike cover.
It'll be fine.
DarkStaR
NoisyDante
I'll cover it if I plan on not using it for a period.  If I'm riding it everyday I don't put it on.
AdamX
Usually got a cover on in the garage.
2001 Monster 900S ie
2001 Piaggio Typhoon 70cc malossi ;D
if you got a garage like ducapinter with bats  n shit. id cover that up. but my garage only has dust and i could care less about dust.
NoisyDante
Quote from: He Man on February 21, 2010, 10:43:39 AM
And you've got some bigger issues than dust right now, isn't that right?   ;)
battlecry
If your garage has windows or glass panes you may want to cover your bike from the eyes of those with no need to know...
DucHead
I keep my bike under the cone of silence.
