ECU serial# for 2007 S2R1000 (Canadian bikes)
Started by jammer, May 30, 2008, 12:26:11 PM
jammer
Hi all, another TOB refugee here.
I posted this question on TOB (just as the changeover was happening) so I'd thought I try here.
I'm not sure if there are differences in US vs Cdn models...but can anyone with an '07 S2R1000 (Canadian model) post what their ECU serial number is?
I had my ECU replaced, under warranty, with the following one:
MS2R1000DUCATI048 (EU_UK)
I'm curious about the "(EU_UK)" part for a Canadian bike.
I'm wondering if this is a reprogrammed ECU, originally meant for European bikes.  It's supposed to be a "DP ECU" (according to the dealer and regional rep) specifically programmed to address the bike's popping/surging/etc. issues after the install of a DP midpipe.  Though I doubt it.  It might just be a reprogrammed ECU.
My bike was bought new in Ontario.  I remember seeing the "(USA)" part on the original ECU. Now I have an ECU with the "(EU_UK)" part.  So the ECU was definitely replaced.  I just don't know about it being a DP.
Since the replacement, I haven't had a chance to ride the bike for long enough, or hard enough, for the engine to register above the "Lo" temp, which is when all the popping/surging happened before.
Any other S2R 1K owners (Canadian) can chime in with their serial numbers?
Thanks for all your help!
echelon
I've got an 07 S2R1K.
Where do I find the ECU number and I will go down and check it for you.
jammer
You'll need to flip your tank.  The ECU is a rectangular thingy, close to the edge where the tank hinge rod is.  There's a label on it.
Thanks!   [thumbsup]
echelon
#3
OK ... I'll go check and see if I can find it.
Found it... MS2R1000DUCATI048 (USA)
jammer
numbskull
jammer
Hmmm...it's starting to look like my bike's ecu was replaced with an European-designate ecu.
Any more Canadian  S2R1000's out there?
Note, I have yet to get my bike up to operating temps since the replacement, so it hasn't been popping/surging.  My riding time is severely limited to cooler rides at night.  Even the dealer, upon returning the bike to me, commented that I won't know for sure that the problem's fixed till the engine gets hot.
So I'd thought I check other S2R1000's ecu's....
Thanks for the replies so far!
I replied on the other thread as well and mine is the same as the other U.S. people who have responded...
