Shave 4+ lbs and keep your cold cranking amps!
Started by Dietrich, February 23, 2010, 08:40:33 PM
Dietrich
OK, I finally gave in and got rid of my rear fender, affectionately called the "getto finger nail" by one of my friends.  That metal support bar and fender weighed in at over 4 lbs.  I have been wanting to simply replace the rear fender with a more compact unit, and relocate the stock tail light a bit closer and more tucked into the rear frame rail.  What I came up with as an alternative is not unlike the many self made tai chops, just made a bracket out of aluminum plate, a couple bends, spacers, and curved to fit under the tail light putting everything right where I wanted it and at the angles I thought looked best. Here it is:
pennyrobber
Looks good and clean. Sorry I didn't get to see it in person last night. You know you could save another 4 pounds with a tiny battery right.  ;D
