monster rear taillight out but brake light working
Started by sbrguy, February 24, 2010, 05:30:44 PM
sbrguy
my 03 620 the brake light lights up when you use them but the normal "on" of the rear light is not working are there two bulbs in there or is some fuse broken?
single bulb, dual filament. The "run" filament could be out. Easy to unscrew and check!
sbrguy
oh ok thanks.  will check that.wasn't sure if it was something like that or a fuse or something all the wire connections in back are connected correctly nothing broken there.
The factory wiring connections back there - the blade style connectors, can be bent away from the connection points on the bulb if you manhandle it a bit. So be careful with that.
1157 or 2057 bulb will fit and work, *but* the 2357 bulb is the same external dimensions but built to handle higher vibrations so it'll last longer.
Punx Clever
I had a lot of trouble keeping brake lights in my bike... so i bought an LED tailight  [thumbsup]
2008 S2R 1000 - Archangel
COP TZR
Quote from: Duck-Stew on February 25, 2010, 07:10:48 AM
there's a handy tid bit of information  [bow_down]
mtuduc
I tried the 2357 and still had troubles, so I installed thicker rubber bushings where the tail light housing bolts to the frame. Haven't had any troubles since.
95 M900       chop, cored exhaust, apex clip-ons, crg mirrors, race-tech springs, custom paint (repaired dings :))
sbrguy
tahnks for the info stu, but i think i'm going to use this as an "excuse" to buy the vizi tec led light, ordered that the other day.
with any luck if that thing is as good as the reviews i'm reading from otehr members i should be impressed.  but then again, it can't really be as bright as people are saying right?
