pipe clamp??
Started by flsurfdog, May 30, 2008, 04:31:44 PM
flsurfdog
ok so i need a new clamp that connects the top header pipe to the mid pipe.....not really sure how i screwed it up, but the SOB will only make a 1/4 to 1/2 turn in either direction.....as it is it's too tight to fit over the pipe, and even if i could get it over i wouldn't be able to tighten it down.
so the side of this little sucker says
NORMA
ND 49
47-51
W4
I'm guessing the 47-51 is the diameter range and norma is some company out of germany that makes it....but their website doesn't have a place to order.  I'm going to the dealer tomorrow to find one, but if they don't have it, does anyone know where i can get one?
thanks
06 s2r1000, Apex Clip-ons, Lowered headlight and gauges, HID high/low, Wasen Design front signals, reflectors removed, Mag Performance clutch cover, Rizoma star pressure plate, open airbox, Spark midpipe, Leo Ti slip-on, tail chop and frame plug blinkers
A good auto parts store or muffler shop should be able to help ypu with something similar.
spinned
maybe you need to get the mesh V-gasket and not the clamp.
flsurfdog
Quote from: spinned on June 01, 2008, 10:02:43 AM
uhhh... huh?  ???
anyway.....after an even greater loss in faith in atlanta triumph ducati, i went to home depot and got a hose clamp.    Hasn't fell off yet but what's this mesh v-hasket thing you mention?
teddy037.2
Quote from: flsurfdog on June 02, 2008, 08:09:14 AM
uhhh... huh?  ???
a proper exhaust pipe clamp will probably serve you better... unless it's those cheapy U-bolt types...
You can get these from Mcmaster-Carr (mcmaster.com):
2nd from the top, on page 252.
teddy037.2
flsurfdog
Quote from: Speeddog on June 02, 2008, 09:21:39 AM
sweet.
Thanks  [thumbsup]
