Is it possible to install a 1098 rear sock on a S2R 800
Started by DucMouse the Mighty, March 02, 2010, 02:34:20 PM
DucMouse the Mighty
I was just given a 1098 rear shock and was seeing what all would need to be done to install it on my S2R.
I have looked on the forum and havent seen much info at all.. I just posted in the tech and we will see..
I just figured I would try in here as well..  Any info would be nice..
Matt
spankinâ,,¢
ducducgooseme
Negative ghost rider...not without substantial modification to the bike that wouldnt be worth the $$ or time.  The geometry of the bikes are completely different.
probably high-sided.
Ratfink749
I got a welder, a grinder, some duct tape, vice grips, and bailing wire.  Somehow, with some  [drink] I'm sure we can make it fit in there.  (Functionality may be somewhat affected however..)
Sometimes when you say no, you really mean YES, that is why we have the safe word.. "FLÜGGÃ...ÆŽNKâˆ,â,¬ÄŒHIÅ'βØL∫ÊN"  If at any time the pleasure is too much, simply say the safe word, and we will stop"
Dirty people say:
"yep.. Ducati makes a fine motorcycle.. If your into all that Crotchrocket Bulls@#t!"
ajw85
the 1098's reservoir will hit the wheel.
there are some threads on it around here
