February 05, 2025, 07:47:36 PM *
Author Topic: Lowering guages  (Read 2615 times)
Wonked
« on: March 03, 2010, 08:24:39 AM »
So, after the swapping of my headlight out for the KTM headlight, I've decided I need to lower the gauges. That said, I have absolutely zero fabrication capabilities or welding experience.
Anyone in the Atlanta area done this? I can make it worth your while!
duccarlos
« Reply #1 on: March 03, 2010, 08:31:24 AM »
It's super easy. There's quite a few threads for how to do it. You ust need a Dremel.
The Bearded Duc
a.k.a. duc750
« Reply #2 on: March 03, 2010, 08:31:37 AM »
I'm interested in this as well  Grin
2001 M750 - Sold
Ducatl
« Reply #3 on: March 03, 2010, 08:33:01 AM »
It doesn't look like you have much room with the ktm headlight there...
Wonked
« Reply #4 on: March 03, 2010, 08:49:05 AM »
I've got a fair bit of room:
I've read some of the tutorials, but it still seems a bit daunting....
« Reply #5 on: March 03, 2010, 08:58:22 AM »
its not daunting. if you want it done cheaply mookie found a nice way to do it with rivets. if you want it looking like it came like that, taft sells them lowered already (if he has or he'll modify yours). or if you have a TIG or MIG capable of welding aluminum then you can just do that.
duccarlos
« Reply #6 on: March 03, 2010, 09:31:48 AM »
Damn, I did a search and found nothing. Can anyone pull the info from TOB? I posted results over there and I remember at least 2 threads around lowering that did not require any welding whatsoever
« Reply #7 on: March 03, 2010, 09:40:24 AM »
http://ducatimonsterforum.org/index.php?topic=29422.0
duccarlos
« Reply #8 on: March 03, 2010, 09:55:53 AM »
You can simply cut the top of the U bracket and put the gauges between the triple and the bracket. That's what I did and I followed the advice of many wiser men before me.
« Reply #9 on: March 03, 2010, 09:57:27 AM »
thosel ights have to be lowered theres no space to do that. (not saying the oem light but the OP's light)
duccarlos
« Reply #10 on: March 03, 2010, 10:08:51 AM »
It should fit without lowering the light. I broke down and created a new account in TOB. Mistake, but I did find the old thread. Unfortunately, all the pics are gone and then I remembered that I deleted all my posts in a fit of rage after BP's board was deleted. Not much info to be had, but Nakid might still have the pics and he can explain how he did it, since he's the one that was most helpful when I was doing it.
