February 06, 2025, 10:26:29 AM *
News: Please Help
Author Topic: tank s2r 800 on s4rs  (Read 4138 times)
Desmoss
« on: March 04, 2010, 03:45:33 AM »
i can buy this tank from s2r 800
for 100$ but i'am not sure will it fit on my S4RS??
Thanks for help
p.s. sory for opening new topic,but i couldn't find another tread  Undecided
Mojo S2R
. Dark Mojo .
« Reply #1 on: March 04, 2010, 04:37:44 AM »
Don't be sorry.  If you tried the search then it may not be there.  I've personnally never seen that asked.
Try looking to see if the part number is the same.  Here's a good online Ducati parts manuals source.  http://www.store.commoto.com/parts-ordering.php
I think Ducati.com has them also for download.
Punx Clever
« Reply #2 on: March 04, 2010, 06:42:26 AM »
Different fuel pumps.  S4rs has an oval shaped fuel pump flange while 695/s2r8/s2r1 others have a round fuel pump flange.
So not a direct bolt up.  I'd assume the flange was redesigned to clear the head on the vertical cylinder... so an s4r tank would probably fit on a 2 valve bike, but not vice versa
2008 S2R 1000 - Archangel
Bill in OKC
S4Rs
« Reply #3 on: March 04, 2010, 07:01:19 AM »
I hope it will.  I bought an S2R tank and fuel pump and had it painted.  I'll find out if it fits now that the weather is getting nicer.
Omnipotent Potentate
Personal Pretext
« Reply #4 on: March 04, 2010, 07:16:59 AM »
Have a look at the diagrams. I know the fuel pump is different from one bike to the other. I also *think* the air box on the S4Rs is bigger/positioned differently - which will make for some real problems. The water cooled heads take up a good bit more room.
And if you can find the info, look at the fuel capacity for the two bikes - you might notice a marked difference
Desmoss
« Reply #5 on: March 04, 2010, 07:50:27 PM »
different part numbers !!
for s2r 800 = 586.1.044
for s4rs = 586.1.056
 Undecided
 i just send an e-mail to my dealer...so when i find out,you will know  chug
« Reply #6 on: March 04, 2010, 09:01:52 PM »
Will not swap IMO.
I haven't tried per se, but I have a plastic tanked bike here and the contour underneath is a LOT larger for the S4Rs engine than it is for the 2V engines.
Desmoss
« Reply #7 on: March 04, 2010, 09:42:36 PM »
Will not swap IMO.
Thanks Steve  Embarrassed
do you know maybe from s4r till '06??
« Reply #8 on: March 04, 2010, 10:18:30 PM »
It's Stuart actually, and you're surely welcome.
S4R's (996 desmoquattro engined bikes) ran steel tanks throughout the production run.  The plastic tanks were introduced on the 2V Monsters sometime in the 2005 production year and Ducati didn't want to make a special tank for the S4R (996) Monsters as they knew that the model was being phased out to make way for the S4Rs in 2007 so they just ran the steel tanks.
Desmoss
« Reply #9 on: March 05, 2010, 05:01:30 AM »
yes,few min.  ago i was talking with my dealer,and he said that only tank from s4r testa from'06 will fit my bike!!!
Thank you once more for helping me,and once more sory for my bad english  chug  chug
Bill in OKC
S4Rs
« Reply #10 on: April 02, 2010, 01:05:34 PM »
Your dealer and everyone is right Sad  My S2R tank will not fit.  There are two issues.  The tank's fuel pump area wants to hit the battery if you raise or lower the tank and the ECU is mounted offset to the left and my S2R tank does not have a cutout for the ecu...  So now I have two options, relocate the battery and ecu or buy another tank for an S4R* testa and get it painted the same way my S2R tank is painted.   What the heck I'm going to try relocating the ecu and going to a speedcell type battery first.
edit: I'm getting a battery from this guy:
http://www.customfighters.com/forums/showthread.php?s=256ba687729cb4c28952bd73dc3c6a29&t=31183
« Last Edit: April 04, 2010, 11:57:14 AM by Bill in OKC » Logged
Bill in OKC
S4Rs
« Reply #11 on: June 14, 2010, 07:28:19 PM »
Here is the S2R tank on my S4Rs.  I went to the LiFePo4 battery to move the ecu in & the clearance from one of the fuel pump bolts to the rear valve cover is  *close*  maybe 3/16" but the tank lowers and latches and the bike runs great with the new battery and the S2R fuel pump.  It was an interesting experience.
Christian
« Reply #12 on: June 14, 2010, 07:57:04 PM »
Stu, am I reading this correctly? If one had an S4RS with a plastic tank and wanted to swap to a metal tank they could purchase one from an '06 S4R?
dbran1949
2007 S4RS Black Termis
« Reply #13 on: June 17, 2010, 12:08:09 PM »
Bill
Any difference in fuel capacity?
Bill in OKC
S4Rs
« Reply #14 on: June 18, 2010, 08:23:26 AM »
Not much that I can tell.  I put about a gallon in for the first use - siphoned from a different bike.  Then rode it about 12 miles to work and the fuel light came on.  Then IIRC it took a bit under 3 gallons to fill it up.  I can only look at specs between the two tanks to see that there should be a slight increase.  No leaks Smiley  One thing is that the outside vent hose wanted to rub on the rear belt so it got spliced to the inner vent hose to keep it out of the way.  Also the battery drain hose is no longer needed.  Before this got started I bought a spare battery tray off of ebay to "re-purpose" so everything is reversible.
