February 05, 2025, 08:03:43 PM
Mounting wider rear wheel on 620 ie?
Topic: Mounting wider rear wheel on 620 ie? (Read 1954 times)
620customproject
March 05, 2010, 05:30:04 AM »
I am new to this forum, and I joined so I could get feedback on questions like this. I have a 2003 monster 620 ie and I am doing custom work to it. I want to put a 6" wide wheel on the back and I have a few questions. I spoke to a dealership in the Detroit area and he said that a wheel off of a gsx 1000 would fit between my swing arm, will be 6 inches wide, and will match the stock wheel I have up front. Does anyone have any feedback on this? I am no bike mechanic, me and a buddy are building this bike. If anything, is there anyone who can tell me what to look for in terms of dimensions and spacing. I don't want to buy a wheel and it not fit. I have tried searching for this for a while and never get any solid information.
Please help!
Sincerely,
Dan
JEFF_H
Re: Mounting wider rear wheel on 620 ie?
March 05, 2010, 06:33:09 AM »
I put a 5.5" with a 170 tire on a 620....and it barely fit
i dont think a 6 will clear on the chain side.
620customproject
March 05, 2010, 08:28:44 AM »
What wheel was that? What bike did you get it off of? Thanks for your reply.
JEFF_H
March 05, 2010, 09:04:09 AM »
it was an alpina wire spoke wheel.
but if you are looking for a 5.5" rear wheel, the easiest way is to find a wheel from a 900 or 1000 monster or supersport
02+ will fit without changes, earlier versions will need the bearings changed to your size
mikeb
March 05, 2010, 11:20:45 AM »
Go check the ducati.ms classifieds. There was a guy parting out a 1000 not long ago. Had aluminum swingarm and wheel for very reasonable prices. If you want a wider rear that'd be the way to go.
---edit---
Found it....but someone may have already scooped them up.
http://www.ducati.ms/forums/showthread.php?t=77965&highlight=aluminum+swingarm
Last Edit: March 05, 2010, 11:26:05 AM by mikeb
loves ze desmodromics.
March 05, 2010, 11:31:17 AM »
+1 on 5.5"
You might be able to shoehorn in a 5.75" + 180 tire, but I'm not positive. That'd be an aftermarket wheel like a BST for sure.
