Desmocedici innards
Started by IdZer0, March 09, 2010, 10:05:56 PM
IdZer0
Now I know how the inside looks like:
Desmosedici performance @ ducati herzele part 2
Anyone knows what he's doing to the inlets?
replaced by 2011 848 EVO
csp808
#1
What do you mean looks like he was checking for piston valve clearance during his valve timing adjustment?
well. everytime i hear the music I have to make time to watch Requiem For A Dream, followed by a session of curling into the fetal position, holding myself, and sobbing.
thanks for that.
At one point, he was putting clay on the piston crowns, that's to check for piston to valve clearance.
Typically done when you fit high-comp pistons, or aftermarket ones, just to make *absolutely* sure there's no interference.
Also done if you're changing cam timing in a way that may have the valves closer to the pistons.
I'm pretty sure when he had the dial indicator installed, he was degreeing the cams.
arai_speed
Cool stuff - loved the white wheels on the bike.  [thumbsup]
battlecry
#6
Looking at the way he tightened the cam caps in the first few seconds, he's not an Alfa mechanic.
DucHead
DucatiTorrey
  - real place
Povidius
Mirrors... I don't see them.
DucatiTorrey
  - real place
IdZer0
Quote from: Speeddog on March 10, 2010, 07:31:02 AM
Ah, didn't realize I was looking at the pistons there. Now it's clear.
Punx Clever
Quote from: IdZer0 on March 11, 2010, 10:44:09 AM
You may hand over your man card, keys, and motorcycle now, thanks.
Also, don't let the door hit you on the way out, we don't want ass prints on our door.  [cheeky]
2008 S2R 1000 - Archangel
