February 05, 2025, 08:10:52 PM *
News: Please Help
Author Topic: Tire Size  (Read 2147 times)
mandalorian
« on: March 10, 2010, 06:05:02 PM »
Tried looking for this in the forum,did a search but could not find so forgive me  Embarrassed if I've over looked. What I would like to know is, how many of you run a 190 size tire in the rear. I have an s2r800 with a 180 and am wanting to go to a 190. I realize that I'll create a lack of handling and response. Some thoughts!! Any and all as well as experiences would be appreciated. Undecided
Feral 859
« Reply #1 on: March 10, 2010, 09:31:13 PM »
I haven't heard of anyone running a 190 on a Monster.
« Reply #2 on: March 11, 2010, 02:36:51 AM »
My thoughts are to keep the 180.
Omnipotent Potentate
Personal Pretext
« Reply #3 on: March 11, 2010, 04:53:05 AM »
Well Boba, the most knowledgeable folks on here advise against.
Why do you want a 190? You are already aware of the cons, so what's the pro?
loves ze desmodromics.
« Reply #4 on: March 11, 2010, 05:37:26 AM »
zero pro's to going to a 190 on a Monster other than posing at Starbucks.
JEFF_H
« Reply #5 on: March 11, 2010, 08:48:49 AM »
190 is the tire size for a 6" wheel, profile would be wrong on your 5.5", and may even end up looking smaller than the 180
DucRS
« Reply #6 on: March 11, 2010, 09:45:51 AM »
Would the 190 really make that much of a negative impact? If so, please elaborate.
Black S4RS                               Black Multi S - Sold
Carbon Red Diavel                     ST4S abs - Sold
620 Red.
Personal Pretext
« Reply #7 on: March 11, 2010, 10:24:13 AM »
By mounting a too wide a tire, it alters the tire profile from what the manufacturer intended. More often than not, this will have a negative impact on the handling of the bike. I could manifest as instability, a wobble or who knows what. Also, a larger tire is heavier. So now you've added additional rotating mass to your drive line... that is ALSO unsprung weight
« Reply #8 on: March 11, 2010, 12:45:52 PM »
Not only heavier and unsprung, but its adding the weight to the outside of the wheel - its effect will be more felt than if you were to attach the same additional weight to the wheels central hub.
The profile change can actually lead to a SMALLER contact patch at a lean, because some of the tire's tread will be bent back in towards the rim when it should straight or angled the other direction.
This would be obvious if you grabbed a 4.5" wheel and tried to fit it with a 180 or 190.
I never understand this, adding a bigger tire so people get the illusion that you go fast enough to need it? Silly (especially on an air-cooled Monster).
Mojo S2R
. Dark Mojo .
« Reply #9 on: March 11, 2010, 09:46:19 PM »
I am pretty certain it's been done, but if IIRC those who did changed to a 6 inch rim just like Jeff mentioned.  Use the search at the top of the page and search for 6 inch rim.
