Anyone know any special tricks for this?
Started by Monster Dave, March 18, 2010, 09:43:03 AM
Monster Dave
I have a computer keyboard and mouse that I really like
And until just the other night, it's been out of commission because the batteries in the keyboard had corroded. I decided that because I had not found another keyboard and mouse combo that I liked that I'd try and fix it. So I pulled it out of mothballs and worked on it. I did get the keyboard working again and which made me really happy - the one that I have was really hurting my wrists.
Anyway, since Simple Green did such a good job cleaning the corrosion off of the keyboard I used a little on the mouse to glean it up too. Unfortunately that was a mistake. Using Simple Green on the mouse left the rubber on the sides really really tacky.
Is there anyway to get that to go away? I could certainly go and get another mouse, but if I can avoid spending the extra money I'm all for it - especially since the mouse works just fine otherwise.
Thanks for the advice!
Dave.
Oldfisti
LOL ^
get some sand paper and sand it smooth, like a 200 then a 400 and you should be good. I made that mistake too, it makes rubber really tacky.
Monster Dave
Quote from: He Man on March 18, 2010, 09:48:49 AM
LOL ^
Glad that I'm not alone in making this mistake! I figured that Simple Green would be safe on anything! Anyway, when you sanded it, did you sand it dry or use water?
Next time you're cleaning battery corrosion, try distilled white vinegar.
KnightofNi
Quote from: somegirl on March 18, 2010, 10:27:13 AM
stop bringing science and reason itot his with your safe and proven methods.  :P
this is more funnier.
Black paint in an excellent stain remover.  ;)
Monster Dave
Oh! That would have been a better idea! :)
Thanks!
KnightofNi
Quote from: MrIncredible on March 18, 2010, 10:58:15 AM
that's not "removal" it's a "concealer"
and when you paint the dogs it's pretty obvious.
zooom
just spray the damn mouse with rubberized undercoating for autobody under treatment!
2010 KTM 990 SM-T
Monster Dave
#10
^  [cheeky]
We'll if the sanding doesn't work it'll be a good excuse to get that Razer that I've been wanting...I mean needing....
rockaduc
Just give your mouse to He Man for a few days.  Someone somewhere will throw chicken grease all over it.  Problem solved!!!
sno_duc
Great just great, now I have to clean  [coffee] off the monitor  [laugh]
A conclusion is the place you got tired of thinking
Monster Dave
Quote from: He Man on March 18, 2010, 05:09:02 PM
Do you want water in your mouse? ;)
I was thinking that light wet sanding would protect it to some degree from over sanding the surface.
