April 28, 2024, 01:04:07 PM
Why helicoils suck
Topic: Why helicoils suck (Read 3905 times)
Why helicoils suck
March 18, 2010, 09:42:48 AM »
Some folks may have wondered why I don't recommend helicoils for repairing threads.
This is why:
Not the first time I've seen this happen.
If it were something non-critical, I'd not be so pissed.
But it's one of the two posts that hold the front brake caliper onto the upright on my Dakota.
Some previous 'wrench' did a bush league repair.
NorDog
I don't feel like a
Re: Why helicoils suck
March 18, 2010, 09:59:58 AM »
How do you feel about Time-Certs?
March 18, 2010, 10:35:02 AM »
Quote from: NorDog on March 18, 2010, 09:59:58 AM
I love 'em.
ellingly
March 19, 2010, 05:26:06 AM »
Good. I can finally point my friends to a thread to show why I think helicoils are often the spawn of the devil. It's also why I
used a time-sert in when I did a sump-plug repair
But most people don't believe me and still stick with helicoils, even though the kits (least here in Aus) are about the same price.
Team Ghetto Racing: motorcycle racing and riding on a budget
2006 Ducati MS2R1000 road | 1973 Suzuki GT250 cafe race | 1982 Yamaha RD250LC race | 1991 Suzuki GSXR750 perpetual project | 1984 Suzuki TS250x vintage enduro | 1997 Honda CT110 postie of death | 1982 Kawasaki KH100 bucket racer
March 19, 2010, 05:41:17 AM »
Due to a number of factors, I replaced that Helicoil with another one.
Can't have the truck off the road for the time necessary to get a Time-sert in my hands.
And, the helicoil thread is slightly larger than a Time-sert thread, so I need to consult with the Time-sert folks.
If they can confirm that it's close enough, I'll red loctite a Time-sert in.
Anyone need any M9x1.25 helicoils?
ellingly
March 19, 2010, 05:50:03 AM »
<James May>Cock</James May>
For $50 you can touch my
March 19, 2010, 05:55:02 AM »
You know, I've used a number of helicoils over the years, and never had a problem.
Do we know if anyone
competent
here has used one and had issues?
Because, it's likely wahetever dumbmake the beast with two backs initially installed the one you found is some sort of, well, dumbmake the beast with two backs.
booger
March 19, 2010, 07:46:54 AM »
dumbmake the beast with two backs or no the Time-Sert is a far superior thread repair
2001 M900Sie - sold
2006 S2R1000 - sold
2008 HM1100S - sold
2004 998 FE - $old
2007 S4RT
2007 Vespa LX50 aka "Slowey"
2008 BMW R1200 GSA
scott_araujo
March 20, 2010, 10:26:20 AM »
I've used heli coils but not time certs, though I think from all that I've read that I'd go with a time cert if I needed a repair.
Something you can do to make the heli coil hold a little better...
Install the heli coil with super thread lock, the kind that needs heat and air tools to remove. DO NOT install the bolt yet. Let the thread lock set for say 24 hours or more before you install the bolt. If the bolt doesn't need thread lock don't use it and use some grease or anti seize on it. If it does need thread lock try to use one of the weaker varieties if you can. All based on trying to get the heli coil to stick to the base more than it sticks to the fastener.
As Speeddog says, sometimes you need to use a heli coil. Hope this helps.
Scott
aaronb
March 20, 2010, 10:57:41 AM »
looks like that heli-coil is a thread or two too short, and the bolt bottomed out on the tang (that's what she said)
Milwaukee, WI
'07 s2r1k, '81 honda cb400t
Langanobob
March 20, 2010, 11:48:39 AM »
Quote from: MrIncredible on March 19, 2010, 05:55:02 AM
competent
Yeah, I think you is correct. Not the easiest thing to do, but we're supposed to break the installation tang off after coil is in place. If you look at the picture, the tang is still there and the bolt bottomed out on the tang, which in turn pulled the coils tight around the bolt like a Chinese finger-cuff. So, when the bolt came out, it took the coil with it.
I personally have never had a problem with a Heli-coil, but then I've never used a Time-sert to compare. Looking at the Time-sert website, they come in either carbon steel or stainless steel. For someone using stainless bolts on their Monster, a stainless threads on both bolt and insert can cause galling and seizing and I'd pick regular steel for an insert. I think Heli-coils only come in stainless so that's something to keep in mind.
March 20, 2010, 02:33:21 PM »
We use 'em on the satellites (really).
9 out of 10 rocket scientists agree they be fine
Online
March 20, 2010, 04:19:15 PM »
Quote from: MrIncredible on March 20, 2010, 02:33:21 PM
...and even though rocket scientists often walk in circles...
heli-coils work great...
Time serts given the perimeter clearance to work are a better solution in high torque applications.
But let's face it...
when all you have surrounding the threaded area is .125" or less a time sert isn't gonna work
Langanobob
March 21, 2010, 03:25:43 AM »
Quote from: ducpainter on March 20, 2010, 04:19:15 PM
I remember from a previous epic Heli-Coil vsTime-Sert thread that Time-Serts require the same or even a smaller drill bit than Heli-Coils. That was news to me.
Online
Reply #14 on:
March 21, 2010, 04:17:30 AM »
Quote from: Langanobob on March 21, 2010, 03:25:43 AM
I just did some searching and find the hole size is actually the same.
I stand corrected.
I'll still use heli-coils...
I've never had an issue with them.
