February 06, 2025, 03:47:28 AM
brake indicator not working
Topic: brake indicator not working (Read 7092 times)
Omnipotent Potentate
Personal Pretext
Re: brake indicator not working
Reply #15 on:
March 23, 2010, 03:20:18 AM »
Seems like it's time to find a test light and start poking around. Of the 3 L-spades, one is ground, 1 is always on, and one will only light up when the brake switch(es) are closed. Seems like you might have a break in your wiring.
It's probably not a fuse though. IF it was the tail light wouldn't come on at all.
Fergus
Reply #16 on:
March 23, 2010, 06:17:15 AM »
I had a similar problem that just happened to coincide with the installation of a CA light. The nub between the front brake handle and the light switch wasn't moving very well. The light was always on. I put some lubricant in there and it fixed it up.
NoisyDante
I am Jack's
Reply #17 on:
March 23, 2010, 06:55:32 AM »
I'll check my wiring, I'm finding it weird that neither the front or back brake trigger it, I wonder if that narrows my search in case it's a wiring problem and not the connectors.
In the least this will give me an excuse to clean up some messy wiring.
'07 695 Dark - Quat-D Ex Box exhaust, gold S4 forks, Woodcraft Clipons, CRG levers, KTM headlight, Motodynamics taillight, 14t sprocket, CRG LS mirrors, flamethrower, the usual refinements. * struck down by a hippie in a Prius on September 22nd, 2010.
greenohawk69
Reply #18 on:
March 24, 2010, 08:42:15 AM »
I had a similar case with my OEM light that I switched back and forth to an integrated LED tail (Vizi-Tech: SN490i and now an HSI SupaNova) and the main issue is how you have the lights hooked up. Look at your Ducati wiring schematic and then connect to your CA tail. Mine works now. I have a '97 M900.
"An enlightened people, and an energetic public opinion... will control and enchain the aristocratic spirit of the government." --Thomas Jefferson to Chevalier de Ouis, 1814
There are 4 boxes to be used in the defense of liberty: Soap, Ballot, Jury and Ammo. Please use in this order. -- Ed Howdershelt
NoisyDante
I am Jack's
Reply #19 on:
March 24, 2010, 09:52:53 AM »
Thanks, do you recall what was the issue with your install? I also had considered getting the Vizi-Tech unit.
Ohmic
Reply #20 on:
March 24, 2010, 01:18:27 PM »
Quote from: NoisyDante on March 22, 2010, 04:23:38 PM
...but the brake indicator is not functioning, back or front levers. Admittedly it was also not working with the Clear Alternatives light that was on before, but I thought the light itself was broken, hence replacing it...
Is the brake indicator light level stuck ON(Bright) or OFF(normal running mode)?
Sounds like the issue is upstream. Could be in your brake levers. Most likely the front. But could also be the rear.
The little micro-switch they use are very fragile. If/when they break... they break in a "closed state". It's like brakes are always pressed.
To test:
1. With your bike electrical system ON.
2. Put a voltmeter(DC) on the stock "L" connectors between the BLACK(Ground) and RED(Brake Signal)
3. Check the voltage state. Should be ~0V with no braking applied. And ~12V when you apply your brakes.
'It's NOT a Harley... It's a Ducati!'
Bike#1: 2002 Ducati MH900e #1801
Bike#2: 2006 Ducati Monster S2R1000
Bike#3: 2006 Ducati Sport1000
Bike#4: 2008 Ducati HyperMotard 1100
lazarus7
Reply #21 on:
March 24, 2010, 01:19:30 PM »
run a test light to your factory harness. ground and switched...
see if the fault is between the tail and the switches...
hard to believe both the handlebar AND footswitches both failed...
"...the greatest artists indulge in a 'culpable rivalry' with God." Stanislas Fumet
NoisyDante
I am Jack's
Reply #22 on:
March 24, 2010, 01:22:25 PM »
Quote from: lazarus7 on March 24, 2010, 01:19:30 PM
thats what im thinking too.
The light level is stuck in a running state, not overly bright.
lazarus7
Reply #23 on:
March 24, 2010, 01:34:53 PM »
so NEITHER switch signal is making it to the tail....
test at both switches physical outputs first, make sure theyre functional, then move up and back from there....
Ohmic
Reply #24 on:
March 24, 2010, 01:46:10 PM »
Why both are not working?.... These switches are in parallel. If one is bad it will effect the other.
I see you have third party levers. CRG?
Make sure they are properly aligned on the little tab/switch so that when you press the lever it releases the switch all the way.
Last Edit: March 24, 2010, 01:48:33 PM by Ohmic
NoisyDante
I am Jack's
Reply #25 on:
March 24, 2010, 05:00:41 PM »
Quote from: Ohmic on March 24, 2010, 01:46:10 PM
I'll try that, thanks
greenohawk69
Reply #26 on:
March 29, 2010, 11:13:08 AM »
Quote from: NoisyDante on March 24, 2010, 09:52:53 AM
I was having a problem with the brake light being ON and then not working. I do remember checking and re-checking my wiring and eventually solved the issue. I referred back to the Ducati wiring schematic and the OEM tail - got that to work and then re-installed the Vizi-Tec.
dropstharockalot
Sex-Toy Bludgeonin'
The Teabaggin' Dragon
Reply #27 on:
March 30, 2010, 06:22:08 AM »
NoisyDante, did you ever resolve this situation? I'm considering an integrated tail light unit, but your saga has me a bit put off...
Anyone else that went with an integrated unit - do you feel like you still have an acceptable level of visibility to other motorists, or do you wish you'd stayed with a larger turn signal set up?
///if this is a threadjack please feel free to PM replies, thx in advance for any opinions.
'96 M900
NoisyDante
I am Jack's
Reply #28 on:
March 30, 2010, 02:27:22 PM »
I actually haven't resolved the issue quite yet, but only because I've been so impossibly busy at work. I was thinking I'd have a more informed mechanic take a look at the issue as well, it'll be in the shop soon anyway since I just got new forks to put on.
I think there is a wiring issue somewhere that is just cutting off the signal from the levers to the light. I think it is mounted and wired correctly, and if there wasn't a break somewhere it'd work fine.
I think the visibility is fine, I don't think a larger light or spaced out turn signals are needed necessarily. I'm always wary of people coming up behind me, but the light is brighter than most car lights, so I imagine it just is what it is.
greenohawk69
Reply #29 on:
March 31, 2010, 01:34:50 PM »
Quote from: dropstharockalot on March 30, 2010, 06:22:08 AM
I have the Vizi-Tec HSI SupaNova integrated tail/turn signal unit...and would not go back to the OEM setup. The LED's are so much brighter than OEM...the turn signals are better, but can be seen better at night vs. day. Allowed me to get rid of the ugly OEM setup.
