brake indicator not working
Started by NoisyDante, March 22, 2010, 05:23:38 PM
NoisyDante
I just installed a Motodynamics integrated taillight, but the brake indicator is not functioning, back or front levers.  Admittedly it was also not working with the Clear Alternatives light that was on before, but I thought the light itself was broken, hence replacing it.
Any ideas on where to look to troubleshoot this?
Also, there's an extra wire coming out of the harness which I am not sure what it's for, and it's not included on the install sheet . . . it's the connection I'm holding in the bottom left of the photo, what is its purpose?
lazarus7
ummmmmmmmmm, thats the brake light wire....... [bang] [clap]
what youve got wired up now are the signals....
that lead plugs into the lightbulb lead/ brakelight lead on clear alternatives, etc...
"...the greatest artists indulge in a 'culpable rivalry' with God."     Stanislas Fumet
lazarus7
....basically thees 3 circuits, whether stock or clear alternatives....
Left, Right, and Running light/ Brake light....
need to find the plug end on your clear alternatives for the brakelight...
just plugged right into the factory socket on mine...
lazarus7
see the brakelight/ running light plugs in the center....?
factory fitting.....
perhaps yous is just bare wire....
NoisyDante
Well that's what I suspected, but what I'm confused about is I followed the installation directions, and the turn signals function properly.
The Clear Alternatives light was installed when I got it, so if the harness was modified I wouldn't know.
So I should just figure out which one of those circuits corresponds to the running light and it'll go into that socket?
lazarus7
yup......
its pretty obvious by physically looking at the unit....
left to left side, right to right, center is brake/ running....
hmmm and the more i think about it, i think they share common ground,
so each signal has one connection and the ground goes to the brake....
looks like it in my pic of the clear alternatives, but of course yours may be different...
been a while since i did mine, have to pull the seat and look to refresh my memory...
It seems like you've got the L-spades mixed up?
The thing you're holding in your hand is the license plate light rubber bulb holder.
NoisyDante
Here's the install schema I followed, I feel like I'm missing something.
NoisyDante
This from the site as well:
Park/Brake:
1. Unplug 3 connections from back of
factory tail light
2. Connect to LED tail light with the
following configuration:
Black - Black
Grey/Red - White
Yellow - Red
Note: Color may differ on various models
lazarus7
in your pic, are your red and yellow leads reversed......?
NoisyDante
I don't think so, the yellow stock wire seems to go to the red Moto wire.  The stock wire is not entirely red, it's red/gray.
Quote from: lazarus7 on March 22, 2010, 06:47:00 PM
Not according to MotoDynamic, but according to us :)
Try reversing the two leads = grey/red to red and yellow to white. $10 says it'll work right [thumbsup]
NoisyDante
Quote from: stopintime on March 22, 2010, 06:51:09 PM
And that's why I keep comin back here  [thumbsup]
I'll try that momentarily.
NoisyDante
No dice, didn't have any affect.  I did try another combination but that turned the running light off entirely.
I'm out of ideas. You probably have to get in there with a test tool to find out if you have a broken connection elsewhere. Unless, of course, you can find a broken fuse....
