Moto Alarm
Started by Mac_48, June 01, 2008, 12:07:17 AM
Mac_48
What alarm do you have?  How do you like it?  Why?
This site is bad for me.....It makes me want to spend thousands of dollars that I do not have XD
teddy037.2
a 110 lb. friendly-but-nosey-enough-to-bark-menacingly-at-anything-new lab?  ;D
Don't have it yet, but I will get the Scorpio.
Nice price, plug & play, lots of features.
I like the Gorilla with pager.
if you are enterprising, you can remove it from the box and put it in a 2-piece project case.  The unit has 2 boards inside the box (bulky).
Some people mount it inside the airbox as well.
motion, vibration, tilting, battery cutoff, paging functions.  pretty slick.
TobyDanger
I've got the Scorpio SR-i500 with TR6b remote (which I think they are now marketing as the SR-i600)...   I love the paging feature and the little screen that shows you what type of alarm it is... works pretty good from farther away that I would have expected on a few occasions.
The paging gives me good piece of mind as the Duc is parked in the same spot where my R6 was stolen from a few years ago, albeit now with a much larger, much more frequently used chain and the alarm.
-=TobyDanger=-
"@[=g3,8d]\&fbb=-q]/hk%fg"
Quote from: TobyDanger on June 01, 2008, 03:15:45 PM
Toby, which bike do you have and were you able to install it under the seat without problems? Where? (pics?)
TobyDanger
Same as you, 07 S2R 800...   [thumbsup]
I tried to take pics when I installed but did it at night in a not very well lit garage so none really came out...
I did fit the alarm box and the perimeter sensor under the seat.  The install went pretty straightforward and easy...  I rerouted the power line a few times to find the best placement, pretty much right under the tank hinge and along side the [looks like a heat sink?] at the front of the seat.  The box itself went just behind the [heat sink thing].  The only real modification I had to make was to remove the lid to the underseat box as the alarm box pressed up into that space.  I got the Monster factory harness and everything plugged right up, no cutting or splicing wires...
I'll try to remember to take some pics tomorow...
-=TobyDanger=-
Cucciolo
Is there an alarm that can sense someone entering the bike's perimeter and when someone does come to close it gives a recorded warning? That would be COOL!
