Banjo Bolt Size?
Started by Mr Earl, March 27, 2010, 03:06:01 PM
Mr Earl
Replacing the front brake lines on my M800, and apparently there are two choices for banjo bolt size: M10x1 or M10x1.25 (I'm replacing one of the caliper banjo bolts with a double.)  Can someone confirm which is the right size?
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
All the ones I've seen on Ducs are 10x1.0
Quote from: ducpainter on March 27, 2010, 03:20:24 PM
Anything newer than the early '90s are all M10x1.0 thread-pitch for all brakes and the clutch as well.
Quote from: Duck-Stew on March 27, 2010, 03:46:09 PM
the bolts on my '83 Pantah and my '86 Alazzurra are 10x1 too.
don't know about the Darmah and the GTL.  For all I know they are in Arshins.
AFAIK it's brembo that sets the spec -- all the Italian bikes I know off that use Brembo have 10x1 banjo bolts.
Mr Earl
Thanks - will order the 10x1 double.
On a related topic: How do I specify to Spiegler the relative orientation of the 2 banjo fittings on either end of a brake line?  Both ends of the line need a bent banjo fitting, so how do I tell them the orientation?
There are two numbers.  Angle of the banjo and axis turn
Make the master zero deg on the axis of the hose facing the master.  That means the part closest to the master.  What angle is it?  Write it down.
Now lay the hose flat with that part down.  How does the slave end look in comparison?  If it is not at the same zero how much turn is it?  What angle is the banjo relative to turn?
Try it with an old hose it makes more sense visually.
When I have hoses made I fax them a diagram to be sure.
Mr Earl
Thanks, Ducatiz.  Faxing a diagram is a good idea.  Too bad my 3-D sketching abilities suck...
Mr Earl
Just FYI on this:  Spiegler emailed me and apparently the end fittings are "clockable" by the customer, using a tool that they supply with each order.  So only the banjo angle needs to be specified.
DucHead
The Spiegler usa website has diagrams for all different configurations of fittings.
bdfinally
When I ordered mine from them, I sent a pic taken with dig camera and they were able to ascertain from that. all three line came back perfect. Used string to figure the length, since they didn't info on '00 M750 dark.
Mr Earl
I'm thinking of a different routing than stock, because the clip-ons have changed the arrangement of things.  Maybe a digicam shot with some editing, thanks for the idea.
My biggest worry was the "clock" orientation, which, even if slightly off, would twist the lines.  These clockable fittings that Spiegler has solve that nicely.  As long as the fittings seal right...
Hydraulic swivel fittings have been working right for years.
It sounds like the Spiegler fittings are just a version of them.
Goodridge also has them.  They make the joint bulkier but not by too much.  Some ppl don't like the look.  It would be better to have a swedged banjo on the master end and a swivel on the slave side where you have more visual room
Mr Earl
Quote from: ducatiz on April 01, 2010, 05:18:25 AM
<snip> It would be better to have a swedged banjo on the master end and a swivel on the slave side where you have more visual room
I agree.  I asked Spiegler about that configuration, and they replied that all their fittings are "clockable."  So there you have it.
There will be no FHE for me on this - just rerouted the front brake line to go under the gauges and it worked fine, so no need for custom lines!  [beer]  Will be spending the money on respringing the rear shock  [thumbsup]
