Resetting the Maintenance Indicator
Started by Xiphias, June 01, 2008, 08:32:10 AM
Xiphias
When I start my S2R800, "Main" pops up on the instrument indicator.  How do your reset this?
I'm between the 6,000 mile and 10,000 mile service intervals.
Rob
Hi-ho-hi-ho....its off to the track I go.................
EEL
Push and hold down both buttons before you start the bike. Keep them pressed for a few seconds..
I think..
skurvy
I think you just hold the left button (odo/trip meter button), then key ON. That should reset it.
If you hit the right button (temp/clock), within 5 seconds of keying ON, that will adjust the brightness of the gauges.
I never held both buttons at once though...
herm
Quote from: skurvy on June 01, 2008, 04:31:45 PM
this is what my dealer showed me when my maint indicator was on.. [thumbsup]
carlosbarrios
#4
Yeap, that worked on my 04 S4R.  Press and hold the left button.  Turn the bike on.  Keep button pressed while the speedo/tach needles go up/down, and then turn the bike off.  Now let got the button.  Now you should be all set.
EEL
I stand corrected..but hey..it still works.. [thumbsup]
