Tech question about DC-DC voltage converter
Started by He Man, March 27, 2010, 08:25:11 PM
is there such a device that you can hook up to your bike so it you could hook it up to a device that normally runs on battery only?
mookieo2
What voltage does the device you want to hook up need? There are plenty of converters out there. You need to be more specific.
Major Slow
You cannot argue with crazy because crazy is not willing to be convinced. Hell, it's not even willing to listen to the arguments.
A very thin 200 meter cable to loose whatever is needed? (I don't even know if I'm joking)
My 9V battery operated glove liners (another joke) became MUCH hotter with the 12/13/14 volts off my bike.
Their controller box reduces the heat ~ "a lot" - no idea how much in terms of voltage.
Maybe a/your Gerbing controller can do it?
Major Slow
i found a lot of shit for cars. but stuff for cars arent waterproof and are exposed or huge pieces of equipment.
I googled the topic and it seems others have the same idea as me. Cameras that run on battery only, or other crap. And there are voltage regulators out thre that you could put into a box, but im looking for something premade. They have a LM317 like thing at radioshack. like the dial found on the Fatduc modulator.
What i want to do is power my Go pro cam. The battery life on it is a joke (20-40mins depending on temp, vibration and if its on video/picture mode, yes i am using rechargeables, no i will not just buy $8 lithium batteries every time i want to use it.
When I asked GoPro about a wall charger converter, they told me to get anything with a USB socket and 5 volts.
My point is that 5 volts is what the camera needs to charge.
Are you planning to connect wires directly to the camera, ditching the battery? (extra batteries are only $20?)
Mr Earl
Quote from: ducpainter on March 28, 2010, 01:22:15 PM
What voltage is a cell phone?
Happily, 5VDC.  I'm researching using a (car) cell phone charger guts to power a GPS.  Trouble with most of them (cell chargers) is the power output is only 200-300 mA.  The handheld GPS I've got needs 500 mA.
If you look carefully at the camera, there should be an indication of the power draw.  I don't have a video cam, so can't even guess.
Leo Vince CF slip-ons, '01 SS900 fully adjustable Showa forks w/ST2 springs, rebuilt S4 shock w/Ohlins spring, 748 dog bone, Swatt clip-ons above the triple, Sargent seat, Duplicolor-Dark seat cowl, Rizoma grips, Techlusion TFI, SBK front fender, Evoluzione slave, BMC sport air filter, 14-tooth sprocket, Desmotimes caseguard, S2R side panels, Pantah belt covers, fake CRG LS mirrors, extra black zip-ties, right grip control imprint on tank, de-cannistered, Ducati Meccanica Bologna key ring
Quote from: Mr Earl on March 28, 2010, 01:31:20 PM
So...
if the camera requires less than 500 mA you could theoretically add a 12v lighter socket and a cell phone charger in a tank bag.
Go-pro shows a charger for the HD hero. Part# acarc-001 Have you seen that?
it doenst say anything about mAh. But what i did read on it (Thats not mentioned on the website) is the fact that it says you must use lithiums when in high vibration use.
The problem isnt cost of a rechargeble battery, but the fact that a battery doesnt last very long and if i wanted to just leave the camera on for an hour, id need to carry 6 batteries and swap them out every 20 minutes.
I planned to drill a hole on the backside of the case and put 2 wires that ill solder it directly onto a dummy battery then seal it with some silicone.
ducpainter the SD Go Pro does not support internal charging. the HD Hero support it, but it also comes with a lithium rechargebale pack that is resistant to shock.
