It's Finished....for now!
Started by tonymtber, April 01, 2010, 12:08:04 AM
tonymtber
Finally found some headlights that I like.....
What a change it has made to the look of the bike!
So what else can I now do to it?
DosVerde
Looks sweet, how you liking the clip-ons?
Next? How about removing the airbox and putting a couple of pods on  [thumbsup]
Mr.S2R
heatherp
Brett76
Ducati Monster S2r800
tonymtber
Quote from: DosVerde on April 01, 2010, 12:17:45 AM
Clip ons are good...I dont have them set real low, just a slight downwards angle.  They felt low when I first put them on, but I could probably drop them a bit more now.  Got them direct from the manufacture in the US....Apex manufacturing if your interested.  The owner is a nice guy who was really helpful & knew his stuff.  Price was pretty good to!
http://www.apexmfg.com/cliponsstore.html
Now the pods are a very good idea!  I've put the on a few older custom bikes, but never thought of them on this....now you've got me thinking.  Is there anything I need to worry about (ie sensors etc) if I remove the air box?  Do you know what size pods I would need?
Cheers
Tony
DosVerde
To tell you the truth Tony, I have no idea. I have seen it on some of the US members bikes and like the way it opens up the frame, but I have no idea how to do it.
wrxmy99
08 MS2R1000
<Gone>
08 HM1100S
01 M900Si.e.
03 WR250F
90 XR250
97 ST2
vossy
nice set of lights Tony.
How do they compare vision wise to the original one?
"Life's short" "Ride More"
Monstar_100
hey mate love the new lights, where did you get the lights from?
did you install the lights yourself?
620ie Monster
tonymtber
Thanks WRXMY99. I've already found their site & have been checking out their kits...pretty much a straight bolt on.  I've been bouncing a few emails to Allan over there & he's pretty helpful.
Hey Vossy, they are only for show! :D...to be honest I haven't tried them at night.  Both lights are on all the time so there should be big more light there.
Got them from http://moto-madness.com/index.htm
The lights including the mounting brackets were around $250 US delivered.
Pretty easy to fit, just remove the old headlight & mounting brackets.  I also changed the instrument cluster mounts & mounted them under the top triple clamp (dropped it around 5cm).  I modified the lower part of the bracket that holds the brake cables in place, but I only did this so I can hide all the messy wiring that normally sits behind the headlight.  Only took a couple of hours all up!
sydmonster
Nice work and indeed changes the look of the bike  [thumbsup]
Quote from: tonymtber on April 01, 2010, 12:08:04 AMSo what else can I now do to it?
well... since you asked. ;D
- remove rear huger
- put paint matched rear cowl
- remove side panels
- put matching rim tape
- remove timing belt(s) covers
- lower entire light/gauge/dials assembly (there's a few DIY examples on this board on how too)
- (if you don't ride 2-up/pillion) then fit a nice set of rear-set foot control/pegs to do away with the horridly big OEM ones.
...Sydmonster - down under
Contact me about your mods and what Street Cred Points you can earn!
tonymtber
Quote from: sydmonster on April 01, 2010, 07:24:07 PM
- remove rear huger
Was looking at a custom two tone seat....just so the kids can still come for a ride.
Had a look at the logistics of pulling the air box out & putting pods in.....started playing today & an hour later its all out including a heap plastic bits, hoses etc.  Its amazing how much plastic is hidden away under the tank & seat!
mattyvas
Nice work, the lights look great on your bike.
All the black out work suits it well.
tonymtber
OK OK....so its still a work in progress....
The air box is now gone, fitted a TPO crankcase breather kit & put on some small pods.
So there is a heap of plastic now out of the bike so it should be a bit lighter ;D.
The pods look cool, & there's a bit more performance, but best of all is the sound!  Open the throttle & there is a nice deep growl as everything opens up.  Really above all else the new sound is the best & if you are looking at improving the sound of your bike I would highly recommend this mod [thumbsup] (& its cheap too!)
Will post some pics tomorrow.
