February 11, 2025, 03:58:19 AM
Please Help
Help me fix S2R 800 front end
Topic: Help me fix S2R 800 front end (Read 2995 times)
kman0077
April 01, 2010, 04:50:35 PM »
New owner of a 2007 S2R 800. I'm coming from a 2005 GSXR 1000 (Yes, I wanted a slower bike, perhaps live a little longer).
Anyways, I have problem with the suspension and the brakes.
1.) The brake lever is very firm but I get very little braking for the effort.
2.) The front suspension is very loose and non-adjustable as you all know.
I'm not aspiring to do track days on this machine, I have a seperate bike for that. However, I definitely need to get the suspension firmer to feel safer and get some stronger braking to emergency stop safely and not have to give a death grip in order to do it.
So, I've searched around the forums and found these options
1.) S2R1000 or S4R forks/brakes (Direct fit but expensive, still need re-sprung)
2.) GSXR swap forks/brakes (Cheaper, but need special spaces, anyone making these?)
3.) SBK front end (Requires machining of clamps, not too interested in doing that)
4.) New springs in stock forks, 4-pot brake calipers (cheapest of all, but is the compressions/rebound going to be ok?)
Question 1: What is the weak link in my brake system? I ask this because I am leaning towards the GSXR swap for the better calipers but if the master cylinder is the weak link, I'll still be in the same boat.
Question 2: If I just re-spring the forks, is the compression/rebound going to be ok? It feels ok now with the stock springs, but if it gets messed up, I can't adjust it.
Question 3: Anyone selling/making the spacers needed for the GSXR swap?
Recommedations here for me?
Last Edit: April 01, 2010, 04:56:40 PM by kman0077
1KDS
Re: Help me fix S2R 800 front end
April 01, 2010, 05:05:48 PM »
Gixxer swap for sale
http://ducatimonsterforum.org/index.php?topic=36117.0
SBK swap for sale
http://ducatimonsterforum.org/index.php?topic=36051.0
Every bike I've ever owned.
orenjimonster
I ride it like a Vespa
scoot scoot!
April 01, 2010, 05:12:10 PM »
THANKS!!!!!!! I was thinking about doing the same swap!
Quote from: 1KDS on April 01, 2010, 05:05:48 PM
SBK swap for sale
kman0077
April 01, 2010, 05:42:42 PM »
I'm very much leaning to the GSXR conversion, but I don't need re-valved internals. I think the stock valving will work for my needs and the stock springs should actually work out pretty well with my weight from what I've read...and experienced. So, that one in the link is a bit too pricy for me, although a great deal with the parts, but it's just beyond what I need.
I was just hoping someone on the forums was still manufacturing the spacers.
1KDS
April 02, 2010, 03:02:22 PM »
I believe TAftonomos and Hooligan Machinist make some custom stuff like that
kman0077
April 02, 2010, 03:32:26 PM »
Thanks. I'll send them a message. I just bought all the parts I need except the spacers from ebay for the GSXR conversion.
$200 for forks, calipers, and an axle. I'll rebuild the forks myself with about $75 for seals/fluids. So, this should turn out to be a very affordable solution to the crappy front end.
rockaduc
April 03, 2010, 09:03:35 AM »
You might need to re-spring 'em anyway. Don't forget a GSXR is much heavier than a monster and is sprung as such. Just saying...
If you can see Chuck Norris, he can see you. If you can't see Chuck Norris, you may be only seconds away from death.
cduarte
April 03, 2010, 09:33:09 AM »
look on ebay and look for ST2/ST4 forks as well, they'll bolt right on as well.
here's a set of S2R1000 forks, good price and they'll be orders of magnitude better than what you have...
http://cgi.ebay.com/ebaymotors/DUCATI-S4R-S2R-MONSTER-04-FRONT-FORKS-SUSPENSION_W0QQcmdZViewItemQQhashZitem439e41c5ceQQitemZ290417919438QQptZMotorcyclesQ5fPartsQ5fAccessories
Last Edit: April 03, 2010, 09:37:22 AM by cduarte
jim_0068
April 03, 2010, 09:46:03 AM »
Quote from: cduarte on April 03, 2010, 09:33:09 AM
actually those are a set of S4R forks
cduarte
April 03, 2010, 10:15:17 AM »
even better, straight rate springs...
