February 11, 2025, 12:17:45 AM *
News: Please Help
Pages: [1] 2   Go Down
Author Topic: Thinking of being unfaithful.....  (Read 6780 times)
techno
« on: April 04, 2010, 02:38:15 AM »
.... to the monster that is!
When I bought the S2R800 I knew the brakes and suspension were the weak points of the bike but with my riding skills I didn’t think it would ever matter. Now having ridden a few other Ducs with better grade suspension and brakes I’m starting to get sick of bouncing around. I now know the confidence that comes from good quality suspension and brakes and I’m really not feeling confident anymore. Just cruising around is fine but when I want to push it a bit I really feel like I’m on the edge of control and it could all end up crap so I end up backing off.  (BTW I don’t think this is an issue that rider training will overcome).
I’ve been reading threads about upgrading suspension and brakes on the S2R800 but all the options take a bit of cash and luck finding the right parts. The other option for much the same cost is to upgrade the bike but I don’t feel I need more power than I have and this option would require selling the current ride. This also opens me up to the option of buying something else like a superbike (I’m thinking 848 or even 999’s are getting reasonably priced). Then again I think this is probably overkill and would eventually result in me doing my licence. I also like the street fighter but it will also threaten my demerit points.
So you can see my problem and how my thoughts go around in circles. I’m sure I’m not the first to have this issue. I’m not looking for someone to tell me what to do, just some other experiences so I can decide what to do. Anyone been here before and wanna chime in?
Hey Techno you are a smart man.  waytogo
Had an accident in Tasmania? - www.tas-compo-law.com.au
heatherp
« Reply #1 on: April 04, 2010, 03:09:01 AM »
wash your brain out with soap  Shocked .....  laughingdp
Have you ridden a S2R1000?  Or maybe even an S4RS?  I know they are very different bikes but one or the other may be what you are needing for the better handling. (or does the S2R1000 have the same handling issues?)
I haven't ridden either (or the 800).  But I know what a difference it made going to my 1000S after being on a jap 750.
And then there's always the 1100.
S2R 800 '07
« Reply #2 on: April 04, 2010, 03:27:34 AM »
I was at that point a year or two ago.
Because of the tax policy in my country, I wasn't able to upgrade to a 1k or S4R.
I was already deep into mods on my S2R 800, so I decided to keep going.
Suspension and brakes followed.
My point is: You might find that the 800 is all you need if you upgrade it.
The transformation was huge and I'm now comfortable following SBKs in the twisties and can equal most bikes on the track (well, not the experienced SBK riders)
I want more power, I want Öhlins forks and I will get there one day.
My mods have married me to my bike though - I will probably stay with her another couple of years.
Betty
« Reply #3 on: April 04, 2010, 09:50:10 AM »
Hey Techno, Stoppie has nailed it ... it is a point most S2R800 owners reach at some time. Your best bet is to go back a few months and buy Bazz's S2R1K ... sorry.
Stoppie has been able to console himself with the Norwegian tax headache and I can feel better knowing the S21K was not available when I got my bike. But truth be known the 800 is more than I will ever need on the road, but I still reached this/that point. Having already poured money into the bike and knowing that I will keep her as long as possible I just kept going. Most but not all things will transfer across to the S2R1K ... your luggage and modified pillion pegs for example (afterall you both need to be happy about the upgrade).
The 1K will give you adjustable suspension, better brakes (calipers, discs and master cylinders), a dry clutch (so you have something else to spend money on) and a decent amount of extra oomph without being stupid about it. Other than the heavier clutch it would improve things enough to make a difference without going over the top IMO (and your pillion riding would probably be a bit easier ... see where I am going with this?).
On the downside the spring rates will probably still need to be changed, you may not be able to carry across all your 800 mods and it will cost you money.
We recently had the discussion with Brett76 (http://ducatimonsterforum.org/index.php?topic=36228.0) about the brake options and there are a few other things you may be able to do to improve things without spending too much or swapping the bike. Tweaks to the suspension should make a big difference in your cornering confidence (well it did to me) ... you just don't want to go too far down this path (or any) and realise you are still not happy.
Brakes: pads and master cylinders would be your cheapest ...and may be enough, perhaps even a change of brake lines.
Suspension: you may be happy with the correct rate spring or spacers to set preload and influence the damping by changing oil weight. You probably should do these things with an 1K anyway.
In summary I think the 800 is a pretty good bike for the street but the most desirable modifications are: suspension, brakes and exhaust ... and for each of these it easy to spend $2k+ (obviously there are cheaper options available) ... and that value equation is something only your wife can decide cheeky
I still haven't heard the option of putting the pillion on the 800 and finding something new for yourself Grin
As usual I have probably made things worse and your mental anguish will continue unabated bang head laughingdp
Two dogs
« Reply #4 on: April 04, 2010, 11:55:30 AM »
I concur with Stopie and Betty
I am having enough trouble keeping it in my pants and holding my license
as it is so I did the suspension thing .
My little Duckling goes like stink in the corners now and keeps up with
most of you on the street.
So I will sit on this bike for as long as it takes to find the right s2r1000
or keep it as a commute and grab a SF for play days when the price goes down.
madalf71
relaxing at home
« Reply #5 on: April 04, 2010, 01:01:21 PM »
Hi Techno.
Been there, done that, similar to Stopintimes mods, great post by the way.
Have put the S2R1000 forks on, revalved and sprung on my 800, big world of difference. Just some fine tuning at the moment.
I've kept the same 800 brakes. I'm not one of the last great brakers, and don't do any track days. Different pads will help.
Main thing that won't swap over onto the S2R1000 is your exhaust system, and cam belt covers. Still get the forks worked over though. Oh and yes a whole other lot of bling to look at...clutch.
Keep in mind, that depending on your riding, once you get better handling, you'll probably want some more power, especially if you're chasing others.
So......IMHO, and I'm no drip under pressure (Expert...squirt) have a look and possible ride of a S2R1000.
Cheers.
Madalf.
Betty
« Reply #6 on: April 04, 2010, 01:19:56 PM »
Obviously a madman Roll Eyes cheeky
Just be careful as chasing may also lead to a requirement to brake like 'they' do with their radial monoblocs, etc, etc.
My own upgrades were inspired by trying to keep up with Jukie who I noticed braking a lot later into corners ... new brakes fixed that. Then there was the pogo-ing around the corners that followed ... and the suspension upgrade. Her post-operative lack of mojo then lulled me into a sense of achievement ... now with the mojo returned I am under no illusions as to my lack of ability (perhaps its a lack of faith, or daring).
Everything works in concert - power, braking, suspension and ability . An improve in one area will bring about a need to improve another area. That improvement will then highlight other shortcoming, etc, etc and the cycle continues.
S2R 800 '07
« Reply #7 on: April 04, 2010, 01:58:47 PM »
True, very true - and I love it waytogo
(in my dreams that cycle peaks with me on a MotoGP podium. After that I expect the cycle to reverse...)
Nickati
Yippee
« Reply #8 on: April 04, 2010, 02:05:35 PM »
I totally hear what you guys are saying but my cycle never changes, all the issues are with me !
Life's TOO short to go slow !
Betty
« Reply #9 on: April 04, 2010, 03:09:54 PM »
Now come on play fair ... different baseline you're talking about there.
But regardless of the relative abilities of machine and rider ... sometimes it may seem more hard work than it is worth. If you are starting to struggle with the machine it is time to make changes so you can start enjoying yourself again (or increase your enjoyment nearer to others).
monstermick58
« Reply #10 on: April 04, 2010, 05:41:46 PM »
MMM....... All very interesting reading, and I would agree on what has been said regarding suspension upgrades and also ditto with brakes, on brakes you could start with a simple upgrade of brake pads and go from there. What would you do next? How about an upgrade of yourself? Talking about some rider training, learning to get the best from your bike in the most economical way, I dont profess to be the best rider around far from it, but I do find it gratifying knowing that I got the best from the bike regardless of who is out in front, so, think about an upgrade for yourself.
Just my 2c worth (hope it helps)
                         Mmick
mostro900
« Reply #11 on: April 04, 2010, 06:59:56 PM »
                         Mmick
I certainly think your words count on this Mmick. I certainly respect your ability on the bike and I would not hesitate to state that of all the riders I have been on the road with, that you are definitely in that small top group of very capable riders.
Basically, I won't cloud the issue further techno, but I for one would listen to that wise sage, monsterrmick!  waytogo
03 M900
04 ET125
08 Sherpa
'when in doubt apply throttle' - it may not save you, but it will end the suspense
monstermick58
« Reply #12 on: April 04, 2010, 08:36:03 PM »
Basically, I won't cloud the issue further techno, but I for one would listen to that wise OLD sage, monsterrmick!  waytogo
Thanks but.... Embarrassed Embarrassed Embarrassed  also fixed the 'sage' bit for ya.
                               Mmick (adding another 2c worth, letsee thats now 4c)
madalf71
relaxing at home
« Reply #13 on: April 04, 2010, 10:46:13 PM »
Howdy All.
OK the issue is getting a tad cloudy, we can't see the forrest for the trees.
S2R800 standard forks are just OK for metro commuting and that's about it.
I defy any S2R800 rider with standard forks to say that they aren't.
Spider will attest to how far I backed off on anything but smooth corners on Gippy ride last year.
FYI, I still have my standard forks stored if anyone wants the experience.
Techno, it's either rework em, fork swap or other bike.
Food for thought, if you put a nice set of forks on your 800, if/when you do decide to power up to a 1000, you can take the forks with you.
Cheers
Alf.H.
CairnsDuc
« Reply #14 on: April 04, 2010, 11:09:34 PM »
I wrestled with this Demon with my S2R 800 and I decided to go down the upgrade path, but I did it while also keeping a close eye on the bottom line, I also was happy with the suspension until I realized just how bad it was, so I looked at a number of different options and found (for me anyway) I replaced the rear shock with an Ohlins from Motowheels and put new springs and different oil in the front forks, all up cost about $1000. Massive amount of difference!  waytogo
Until the budget allowed I ordered new brake pads from CA Cycleworks and that made a world of difference, still never as good as a set of Monoblocks, but still much better than OEM.
I managed to get one of the last Goldline upgrade kits for the S2R 800, Night and day difference, still not as good as the Radials on the S4R, but pretty damn close
All up for the front brakes it was $900
You can chase up the brakes from wrecked bikes and the like (Keep an eye on the Parts for sale board and Ebay) but my personal thoughts, spend the money on the 800, they are a great bike, and it's not such a massive jump to fix those problems
Pages: [1] 2   Go Up
