Oberon clutch slave......
Started by mikeb, April 04, 2010, 03:52:40 PM
mikeb
....should come stock on all dry clutch bikes!
Just installed one on my S2R 1000 and man what a difference.
That is all.... [thumbsup]
vwboomer
Im pretty happy with mine and the price was great  [thumbsup]
2005 S4R - Sato, PM, CC, Sargeant
2005 GasGas FSE450
2004 Honda VFR
uclabiker06
The difference is that noticeable ?
2006 S2R
2009 Smart
it is if you have a dry clutch and weak hands.  ;D
mikeb
Quote from: uclabiker06 on April 04, 2010, 06:47:09 PM
Yes, it is very noticeable.  Not only is pull much easier it increases the friction zone of the clutch.  In stock trim all the modulation is in first 1/2 inch of lever pull.  The new slave increases the range of modulation.  Fanning the clutch in traffic is much easier because the pull is easier and the lever has a more workable range.
mikeb
Quote from: He Man on April 04, 2010, 06:56:21 PM
Or those tiny Burger King hands.  ;D
If it is still too heavy, remember you can always pull two springs, or put washers under the spring caps or do both!
Especially for you guys who don't have a leaky slave and aren't ready to spend the cashmoney yet.
WhiteStripe
2006 S2R 1000, Arrow CF exhaust, FatDuc 02, CF open cc with stock pp
Bizzarrini
Quote from: a m on April 05, 2010, 04:43:36 AM
How do the washers work? I'd think they increase the spring preload, thereby increasing the force required to pull the clutch?
"As a final touch, God created the Dutch"
Under the spring caps. Lessens spring preload. You put them under the spring cap, between the hub post and the cap - you don't want one with a diameter large enough to contact the spring itself.
Bizzarrini
Ah ok, got ya! No clearance issues with the clutch cover that way? (quick reaction by the way!)
No issues on my Rizoma cover, using rizoma spring caps and pressure plate
arai_speed
My results were marginal at best - it did make a difference but not one to write home about.
mikeb
Quote from: WhiteStripe on April 05, 2010, 06:52:31 AM
did you install it your self?
Yes, I did.  If you are at all mechanically inclined you won't have any trouble with it.  Probably one of the easiest mods to do.
uclabiker06
would it be worthwhile to put on a wet clutch?  Like, say an s2r800?
2006 S2R
2009 Smart
