January 04, 2025, 11:47:44 PM
Mushy front brakes -- need advise
Topic: Mushy front brakes -- need advise (Read 3110 times)
Odeccut
June 01, 2008, 06:55:07 PM »
Hi guys! I need help: my front brake goes soft on me every once in a while. Most of the time it is fine, but every once in a while I can pull it almost all the way to the grip. The brake engages and stops the bike well, but I am just worried as to why every once in a while the travel of the lever changes so much. In addition, I am keeping the lever adjusted kind of far from the grip, because if I adjusted it closer, I am afraid it will run into the grip one of those times and I will not be able to stop the bike. Any ideas? I tried bleeding the brakes a few times, but I am kind of new to it... Please help -- I am getting really nervous about this.
Re: Mushy front brakes -- need advise
June 01, 2008, 07:06:23 PM »
Air in the line is possible, but it usually doesn't come and go.
A bad master is a possibility too.
mdriver
June 01, 2008, 07:47:00 PM »
Don't take chances like that.
If its not leaking, and bleeding it doesn't help right away, change the master cylinder.
Bike Info: 2001 Ducati M750 Dark, 2007 Triumph Bonneville
June 01, 2008, 07:48:08 PM »
Which master cylinder do you have, Goldline or Coffin?
How old is your bike?
June 01, 2008, 10:00:08 PM »
check for loose bolts, then rebleed. then see if it fixes the issue. if not, check for leaks
Odeccut
June 02, 2008, 06:27:52 AM »
Quote from: Speeddog on June 01, 2008, 07:48:08 PM
The bike is an '02 620. It has coffins. The problem started when I loosened the banjo bolts to get my handlebars fitted -- I needed to move the brake lines around. While messing with it, I had the reservoir open and like an idiot pulled the brake lever -- don't ask why
. The brake fluid shot up into the air... Anyway, I put it together, bled the brakes, but ever since then it goes mushy every once in a while.
teddy037.2
June 02, 2008, 06:42:46 AM »
Quote from: Odeccut on June 02, 2008, 06:27:52 AM
sounds like you just have air somewhere. have you bled the MC by itself?
mighty vac also helps. makes bleeding stuff a snap
Desmostro
alis volat propriis
June 05, 2008, 08:43:18 AM »
Quote from: teddy037.2 on June 02, 2008, 06:42:46 AM
How do you do that? Details of the best way please?
Omnipotent Potentate
Personal Pretext
June 05, 2008, 09:20:04 AM »
Quote from: Desmostro on June 05, 2008, 08:43:18 AM
Some, but not all, Masters have bleeders on them. So you bleed at the calipers to replace the fuild and get ride of old gunk. Then you can also bleed at the top, since air rises in the fluid and bleeding from the bottom may take longer/may not get it all.
If you don't have a bleeder on your master, you've jsut got to do it from the calipers the old fashioned way.
June 05, 2008, 09:43:22 AM »
Coffins have no bleeder on the master.
You can bleed it by having some one squeeze the lever and holding a rag at the banjo and just crack the fitting while it's being held with pressure on the lever.
Works great except for needing an extra hand.
teddy037.2
June 05, 2008, 01:08:24 PM »
Quote from: ducpainter on June 05, 2008, 09:43:22 AM
+1
and not making a mess of yourself and the fluid
bled my goldline clutch master that way, since only the brake master had a seperate bleeder.
June 05, 2008, 06:37:39 PM »
The master should be as close to level as possible. Wire tying the lever in the applied position over night can help too.
