February 11, 2025, 12:25:24 AM *
Pages: 1 [2] 3 4   Go Down
Author Topic: Front Brake problems  (Read 6936 times)
brimo
酒後吐真言
« Reply #15 on: April 11, 2010, 12:42:32 AM »
how old is the fluid, hot brakes, moisture in fluid, expansion, locked brakes.
From a story by RAT900
Dockstrada
« Reply #16 on: April 11, 2010, 12:45:32 AM »
It has done  7 or 8  track days , with in this time a set of OEM pads.
If I wasn't who i was, I wouldn't be who I am !
Nickati
Yippee
« Reply #17 on: April 11, 2010, 12:48:39 AM »
If you take the caliper off and push the pistons back without the retainer springs in do the pads slide freely ??
Any burrs on the pads ?
Retainers bent ??
Life's TOO short to go slow !
brimo
酒後吐真言
« Reply #18 on: April 11, 2010, 12:49:26 AM »
Air in the lines will expand a lot when hot too
Dockstrada
« Reply #19 on: April 11, 2010, 12:53:55 AM »
Retainers bent ??
Yep nice and free ,Can't see how the retainers would have an effect on the pads in that direction if it was bent .It is only to keep the pads in the caliper and not as a slide.
I think I'm heading down the expanding fluid/moisture/air direction  Huh?
brad black
« Reply #20 on: April 11, 2010, 12:54:48 AM »
undo the grub screw locking the m/cyl piston pushrod adjuster and wind it out a turn and see if that changes anything.
Brad The Bike Boy
http://www.bikeboy.org
Dockstrada
« Reply #21 on: April 11, 2010, 01:00:10 AM »
Tried that , I have these leavers fitted to it with all types of adjustments,The red nob reduces the pressure on the piston rod .
Nickati
Yippee
« Reply #22 on: April 11, 2010, 01:05:04 AM »
Can't see it being the fluid, but hey there's always something to learn even after years  in the automotive industry !
brimo
酒後吐真言
« Reply #23 on: April 11, 2010, 01:06:17 AM »
Yeah,  sorry, I never asked, is it one or both calipers seizing? Hard to tell I know, but aids a lot in the diagnosis.
Dockstrada
« Reply #24 on: April 11, 2010, 01:10:21 AM »
Sold a bike to a guy once ,an Aprillia RSV. 20 minutes later he rings me telling me hes stuck on the side of the road and the back wheels locked.
He called me back after a few days,turns out he was riding the rear brake and locked the wheel when the fluid expanded.
Dockstrada
« Reply #25 on: April 11, 2010, 01:11:16 AM »
Be difficult to find out  if it was only one caliper Huh?
Nickati
Yippee
« Reply #26 on: April 11, 2010, 01:13:42 AM »
Heat can do strange things
brimo
酒後吐真言
« Reply #27 on: April 11, 2010, 01:47:53 PM »
If you've got it up on a stand, put some pencil marks (or Bearing blue or texta, but not too much) on the disc, get a mate to turn the wheel and
listen at the caliper to see if you can tell by the sound, otherwise check to see if the pencil /bearing blue marks have rubbed off.
Betty
« Reply #28 on: April 11, 2010, 05:29:21 PM »
OK Dock I have applied my almost incomparable mechanical and motorcycling knowledge to your query and identified the problem and offer a solution.
It would seem your poor tortured bike is mounting a protest at the hard life it has led. So the most obvious solution is to find an appropriate home for it as it is like a little puppy that can't be cared for appropriately.
We can offer this poor unfortunate a loving home where it will be surrounded by friendly faces that will not intimidate such a youngster. I can only assume you are just days away from posting up 'free to a god home' ... and when you do remember us and this post, we will do what we can to help.
Oh yeah and the added advantage is I could ride the bike with the handbrake on and probably not realise its capabilities have been restrained.
Everybody wins!
Dockstrada
« Reply #29 on: April 11, 2010, 08:38:57 PM »
Her working days as a track wench are not over yet Betty,She'll be ridden hard for some time yet as was the R1 Evil .But when she is ready for pasture I will keep you in mind. waytogo
Pages: 1 [2] 3 4   Go Up
